RSX Key Blank cut to my car locks
Old Jun 11, 2012 | 10:13 PM
PURPLERANGER's Avatar
Icon2 RSX Key Blank cut to my car locks
I don't know if my title made any sense, but what I'm trying to ask is, if I were to get a blank Acura RSX key and get it cut, the same way my old Integra key is, will I be able to use it, or will there be some kind of electronic program in the key screwing everything up?. I have a 96 which I'm quite positve did not come with the Immobilizer, and i'm guessing the RSX key will work, but I'm aisking to double check, and because I just want to try something diffrent, then the old bland Integra keys.
Old Jun 12, 2012 | 04:43 AM
TheRealTegger's Avatar
Default Re: RSX Key Blank cut to my car locks
If you don't have a little key-icon lit up on your dash when you first turn the key to "II", then you don't have a factory immobilizer. AFAIK, the Integra didn't come with factory immobilizer until 2000.
As for the key: as long as the RSX's metal part matches with your Integra's metal part, then the key will work. Go to a hardware store and compare.
In fact, you're not wedded to an RSX key. You could use any Honda/Acura key whose metal part matches your Integra's key.
Old Jun 12, 2012 | 04:07 PM
thanks
r1ckynutz
Jul 18, 2012 07:04 PM
MrHeeltoe
Apr 21, 2010 11:50 AM
KidFrost
Oct 14, 2008 11:43 AM
CJ0
Jan 5, 2008 09:23 PM
A
Oct 18, 2001 10:45 AM
