Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Gear question about VIR
Old Oct 14, 2002 | 11:28 AM
drumsy's Avatar
New User
Default Gear question about VIR
My instructor (Jim Pantas ) worked with me on reducing my shifting as much as possible. I inquired about if I'm going into a corner, and say drop it into 2nd, but immediately have to shift to 3rd coming out of it, if that's something good or bad to do. He recommended I keep it in 3rd, and mentioned that everytime I shift, that's a second off of my time. Is there any input into this?
What gear did most of you take turn 7 in?
[Modified by drumsy, 3:37 PM 10/14/2002]
Old Oct 14, 2002 | 11:33 AM
Back in Black's Avatar
Rather OG
Default Re: Gear question about VIR (drumsy)
Keep it in 3rd, IMO. Jim Pantas does own. He's helped me much, and was also one of my instructors in the comp school at CMP
Old Oct 14, 2002 | 11:36 AM
Honda318dx's Avatar
2nd should not be used at VIR at all, except oak tree... Even if your off hi cam, you loose time shifting... But, I do use 2nd when held up, or 2 wide often, because obviously, my speeds are slower than from a hot lap..
Old Oct 14, 2002 | 11:40 AM
JeffS's Avatar
I was in 3rd. Same engine as you, lighter car.
One instructor had me think about it like this... 2nd might be able to work for you right now. If you know that you'll eventually be fast enough to need 3rd, then you should use 3rd now. This will prevent you from re-learning your shift points later on. Plus, "seat of the pants" can fool you into thinking you're going faster when you're not.
Old Oct 14, 2002 | 11:46 AM
6ghatch's Avatar
I would say keep it in 3rd up turn 7.
I have the ATS 4.9 F/D and it seemed to be a help and a menace at the same time. I was able to pull harder (in 3rd gear) in turn one and seven, but was forced to upshift to 4th for turn 2,6 and 9+. Anyone else with the ATS find the same results?
[Modified by 6ghatch, 3:47 PM 10/14/2002]
Old Oct 14, 2002 | 11:47 AM
Mike_C's Avatar
Default Re: Gear question about VIR (6ghatch)
Could the reason he said to keep it in 3rd possibly be because he has power everywhere and anywhere in his rustang?
Old Oct 14, 2002 | 11:50 AM
Rather OG
Why is shifting into 4th a "menace"?
Old Oct 14, 2002 | 11:52 AM
drumsy's Avatar
New User
Default Re: Gear question about VIR (JMU1337)
Probably. After getting a ride with him in the last instructor's session on Saturday, I have a newfound respect.
Daniel - The guy with the video camera in hand
Old Oct 14, 2002 | 11:55 AM
Mike_C's Avatar
hehe, heard about that on the net.
Old Oct 14, 2002 | 11:56 AM
6ghatch's Avatar
Default Re: Gear question about VIR (Jason Franza)
Poor choice of words, I don't mean it's a menace but seemed to require a few more up and down shifts in some tough areas.
In the schools we are taught to keep shifting to a minimum. Also, it was tough to keep the car steady when heel/toe downshifting in the turn 3. (due to lack of straight braking zone)
[Modified by 6ghatch, 4:01 PM 10/14/2002]
Old Oct 14, 2002 | 12:06 PM
Rather OG
No argument there. Eliminating shifts is a great thing, and will make you much smoother of a driver. 3 is quite tricky. I've actually been working on going through there in 4th instead of downshifting back to 3rd, but still have a good while before I can say it works "well" for me. I do LOVE that turn though, and if you take it right, you can make up some major ground there
Old Oct 14, 2002 | 01:17 PM
Crack Monkey's Avatar
This is one of the items Dan wanted the Adv students to work on over the weekend. Some of the Mustang guys were doing the whole track in 4th and most said after a few laps they were carrying enough speed through corners (including 7) to make it work. Of course, in our torqueless imports, 3rd is required on occasion.
I was taking turn 7 in 3rd in the RX-7 (2500lbs, 100hp). I imagine you could do the same. The only place at VIR I use 2nd gear is Oak Tree (and on fresh tires and a few more practice sessions, I may not dip down there either).
Old Oct 14, 2002 | 05:38 PM
.RJ's Avatar
.RJ
Default Re: Gear question about VIR (Crack Monkey)
yeah, i'm in 3rd gear for 1-2, shift into 4th and ride through 3, back to 3rd for 5/5a, shift into 4th as entered 6, back to 3rd for 7 and carry 3rd into T10, where i'm shifting into 4th for the exit. I also had a tricky time into 16, where i'd be in 4th on entry but shift to 3rd for my entry/exit for 17.
RJ
Old Oct 14, 2002 | 05:48 PM
krshultz's Avatar
I experimented with 2nd in T7. Worked fine until I found that I could do the corner much faster than I thought. Revlimiter at the middle of the hill = bad.
I used 2nd in T1 during lap 1 of the race since we were slow due to traffic. Otherwise I echo what others have said - 3rd gear + all around VIR except Oak Tree.
BTW, I have the stock final drive in the car, and plan to keep it.
Just a n00b
Acura TSX
Jul 29, 2010 04:01 PM
mixxed
Transmission & Drivetrain
Apr 19, 2010 07:32 PM
Chris F
Jul 18, 2005 07:47 PM
UA6 BALLER STATUS
Apr 4, 2004 06:38 PM
