Magnetic oil drain plugs
Old Jun 11, 2012 | 10:20 AM
GoLowDrew's Avatar
Old Member
25 Year Member
Icon5 Magnetic oil drain plugs
We all seen how much metal shavings the AT plug can attract. That how AT suppose to be. That's why it's magnetic.
What about engine motor oil drain plug?
Does it work just as effective? Or there should not be that much metal shavings from the engine?
Sure, I could try it. But why spend the $$$ if I don't have to.
Your take on magnetic oil drain plugs?
Old Jun 11, 2012 | 10:24 AM
doood's Avatar
been there done that
Default Re: Magnetic oil drain plugs
i always get small amounts of shavings on my magnetic plugs. not enough to really make me worry.
Old Jun 11, 2012 | 10:29 AM
GoLowDrew's Avatar
Old Member
25 Year Member
I know they are cheaper. But does it make you spend $30? Let's just say, is it a $30 worry?
Old Jun 11, 2012 | 11:07 AM
doood's Avatar
i got the oil and tranny plugs for about $30. so to me it was worth it. it's only $30.
Old Jun 12, 2012 | 11:32 AM
GoLowDrew's Avatar
Old Member
25 Year Member
For you Honda experts. Are oil drain bolts and ATF drain bolts the same for all Hondas?
To be specific, K24 and J35. I asked the vendor and gotten no response. They only list the I4 but not for the V6. And is the bolt the same for AT and manual? Agian, they only list "transmisission" bolt.
Old Jun 13, 2012 | 05:14 AM
HondaPartsHero's Avatar
Technical Hero
This site lists all drain plugs from 84-11 as the same
http://www.cgenterprises.com/honda_1992_96.htm
Old Jun 13, 2012 | 12:13 PM
GoLowDrew's Avatar
Old Member
25 Year Member
Thanks
Old Jun 15, 2012 | 12:35 PM
spAdam's Avatar
Loved
Community Favorite
This is on a brand new b20 build at its first oil change. Can't imagine its gonna get any worse from here unless I screw something up down the road.
Old Jun 15, 2012 | 01:09 PM
GoLowDrew's Avatar
Old Member
25 Year Member
I placed my order, and will install it on the next oil change, for both my cars. My engines are 30K-45K miles. I wonder what I'll see?
I'll update in a 6-8 months.
Old Jun 16, 2012 | 03:24 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Shouldnt look any worse than the picture above.
Old Jun 16, 2012 | 07:06 AM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
I'm not sure who has them,but the best one I've seen is that high power magnet that slips over the oil filter, the entire filter becomes magnetic, when you change the oil you simply move it to the new filter, one of the few gimicky items that actually does something useful, the magnetic drain plugs work, but have a very small surface area.
Old Jun 18, 2012 | 10:42 PM
jooky5's Avatar
I stick a large magnet to the oil filter. That way the metal bits stay in the filter and when I change out the filter i slide off the magnet to the new filter.
Old Jun 19, 2012 | 06:47 AM
GoLowDrew's Avatar
Old Member
25 Year Member
Since I already ordered my plugs, I'll be going a different direction.
For my info, I'm trying to figure this out, where do you put the magnet? IRCC, when you remove the oil filter, it looks like this:
|_|
the long part where to you screw the filter on.
OK, as I type, I think I know what you are saying. Put the magnet on the OUTSIDE, on the oil filter body.
Right?
Old Jun 19, 2012 | 08:09 AM
spAdam's Avatar
Loved
Community Favorite
They have ones that slip around the filter. You can also epoxy something along the lines of a cobalt or rare earth magnet to a hose clamp and put that around the filter.
Old Jun 19, 2012 | 11:12 AM
GoLowDrew's Avatar
Old Member
25 Year Member
Can someone tell me which one is which?
I'm seen it listed both ways. Is the longer one for the engine or trans? Or does it matter? The transmission normally should have more shaving, right?
Old Jun 19, 2012 | 01:46 PM
put a small spin on filter and adapter between the one of the tranny cooler lines and the radiator connection, then stick a big magnet on it, it will filter a heck of a lot better then the screen in there
Old Jun 19, 2012 | 05:27 PM
MojicaEric's Avatar
A tranmission is always going to a very minimun amount of metal in it. You really shouldnt have any to none on your engine oil plug only on a rebuilt engine will you see the most.
Old Jun 19, 2012 | 08:56 PM
spAdam's Avatar
Loved
Community Favorite
The long one goes in the oil pan. It will hit the diff if you put it in the trans.
Old Jun 19, 2012 | 09:00 PM
FlewByU352's Avatar
My coolant drain plug was covered in that black sludge shavings. I wasn't sure if the water pump was saying **** you or the new radiator just has that much **** in it from manufacturing.
Spawne32
Mar 12, 2011 08:18 AM
CRZ1
Apr 26, 2009 08:59 PM
johnnyqsack
Jul 7, 2006 10:15 PM
teler86
Mar 6, 2005 09:53 AM
