help with transmission leak
Old Jun 11, 2012 | 09:01 AM
japcarmad's Avatar
Default help with transmission leak
ive got a 1999 euro accord auto and ive found this leak on my transmission.
anybody had a similar problem?
thanks
http://i48.tinypic.com/1e2n0z.jpg
Old Jun 14, 2012 | 01:35 PM
jr_soliz2010's Avatar
Default Re: help with transmission leak
leak on the transmission? can you pinpoint where its coming from?
Old Jun 20, 2012 | 08:57 AM
japcarmad's Avatar
yes i know its coming from the transmission but i cant pinpoint it.
Old Jun 21, 2012 | 08:50 PM
MAD_MIKE's Avatar
MM Gruppe B
thanks
That looks to be the shift cable (control cable in Honda speak) if the transmission is leaking(red fluid) then its most likely the torque converter seal. If its golden brown then its oil and the rear main shaft seal is leaking.
Old Jun 21, 2012 | 08:55 PM
PhatAccord92's Avatar
10 Year Member
could be the shift shaft seal if your trans fluid is low. if your engine oil is low, could be the rear main oil seal
Old Jun 25, 2012 | 09:48 AM
japcarmad's Avatar
update - so i clean of the area after a drive and it seems its leaking bad straight after ive been driving. the leak looks like its coming from the cable or directly above it (shaft seal). going in on tuesday to get it up in the air and have a good look. also got a fukin locking nut on thats been snapped by the previous owner and i cant get it out lol.
OriginalSandman
Nov 9, 2015 04:51 PM
RA21625
Transmission & Drivetrain
Apr 1, 2015 03:47 AM
johnzy00
Honda Civic (2006 - 2015)
Jan 9, 2012 06:45 AM
smithenhiven
Dec 12, 2011 03:50 PM
piggiepigg
Jun 16, 2007 07:27 PM
