need help on my swap
i am swapping a b20z2 into my 1991 si crx. the b20 has been switched over to an obd1 motor with harness and i am using the crx interior harness with it so i baught an obd0 to obd1 jumper harness for the ecu which is a p28 chipped with LS mod ive got all wires pluged in on the motor side and all on the inside i am wondering what i would have to do or splice and witch wires i would have to cut to get them to connect any help would be great. really need the car done thanks.
your not making a whole lot of sense. which wires dont match up? assuming it was done right, your now obd1 harness should plug right into your shock tower plugs and then your ecu jumpe will have its own wires running to the harness. should look something like this:
http://youtu.be/puPiwS11hOQ
this is a DPFI to OBD1 Vtec conversion harness i made, but you get the idea
richboi
Jun 1, 2009 12:35 PM
hatchinprogress
36
May 4, 2006 09:16 AM
