1997 Accord M/T Leak?
I have a 1997 Accord coupe with a 2.2 coupled with a 5 sp manual (251000 miles). I noted a drip leak from the transmission last fall. I swapped the input shaft seal and it continued to leak. I swapped the seals on the shift linkage and put some heavyer gear lube in...still leaked...I thougth perhaps I has warped the input shaft seal so I knocked it back off and re replaced it...pulled the upper shift linkages off and resealed the cover. Seemed to go away and then...it is back. Anything I am missing? Thank you all.
csilvajr02
Jul 9, 2007 02:49 PM
