*99 lx sedan major power loss uphill, flashing CEL
Old Jun 10, 2012 | 04:20 PM
dmpd_ef's Avatar
Default *99 lx sedan major power loss uphill, flashing CEL
driving up the mountains earlier on the way to eibach and halfways up i start losing major engine power and my CEL starts flashing. pull over to check the oil, turn the car back on and no more CEL and drives perfectly fine once i start the downhill.
for reference i have a small engine oil leak and when it gets too low the CEL stays on and i get code p1259 that has the same power loss but at all times, i erased the code and keep the oil level in check, problem never came back until today, and it was much worse than when i was just driving on flat road
anyone else have this problem that can shed some light. i dont want this to impeded my travels. thanks
Old Jun 11, 2012 | 06:02 PM
Lost Again's Avatar
Default Re: *99 lx sedan major power loss uphill, flashing CEL
Well you know the 1259 is a vtec issue.....most of the time caused by low or dirty oil. FIX the leak!
So are you sure this was the same code? Re-check, most of the time a flashing cel is a mis-fire or other major issue.
Old Jun 14, 2012 | 11:38 AM
Gospeedgo's Avatar
Check all your spark plugs, plug wires(connections at the motor and distributor) Also your distributor, rotor button, etc. Could be an ignition problem.
EP3inVB
Feb 25, 2013 08:55 AM
danewslim2
12
May 24, 2008 07:16 AM
00BLKBB6
Jul 22, 2005 06:28 PM
USSAILOR
Nov 23, 2004 02:25 PM
HYBRIDHATCH92
13
Jan 22, 2004 06:15 AM
