1995 accord vtech and atutomatic tranny plusating
Old Jun 10, 2012 | 10:29 AM
joespunn23's Avatar
Default 1995 accord vtech and atutomatic tranny plusating
what happening everyone just recentnly bought anther 95 accord ex got a great price drove it for a month now mostly around town under 40 mph most part well recently took it on the highway when i get it up to 55 mph it starts plusating almost seems like its running out of gas so speak i take it to 70 mph it seems to stop it now if i keep it d3 at 40-55 mph it dosent do it any ideas guys im thinking either the lock up soliniod or the converter it self ??????? any input would be great also do i need to stay off the highway until problem is fixed ?
Old Jun 10, 2012 | 11:41 AM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 1995 accord vtech and atutomatic tranny plusating
Is it only bucking when in 4th in the 45-55MPH range?
Note the RPMs when it does this, then try the other gears and for that rpm range. See if you note the same bucking/missing/stumble.
If it's around the ~2K rpm mark, and does it only at a steady cruise, I'm going to guess that the EGR is clogged or inoperative.
Clean out the EGR passages and recheck. Make sure the EGR valve is working as well.
Old Jun 11, 2012 | 04:55 AM
joespunn23's Avatar
okay last night took the car to work i paid attention to the rpm range that it occurs it happens what seems to 1900 rpm , tried the other gears nothing now when this bucking occurs i feel some kinda vibration on the floor board , on my nexxt day off i will check the egr valve thanks for the help
Old Jun 14, 2012 | 06:04 PM
Lost Again's Avatar
Not the valve...the PORTS. Buy four new o-rings for the top of the injectors (IMHO) and two cans of carb cleaner and clean the chamber and ports.
Old Jun 15, 2012 | 12:35 AM
MAD_MIKE's Avatar
MM Gruppe B
joespunn23 there is a how to in the FAQ section on how to clean the EGR passages on the 90-93 and 94-97 cars. On the 94-97 cars its a bit easier as there is a separate manifold that can be opened and cleaned out.
Old Jun 16, 2012 | 07:00 AM
Lost Again's Avatar
I highly suggest new o-rings for the top of the injectors.
CompuRIP
Jan 5, 2009 08:17 PM
uEDarkShadow
Apr 27, 2006 07:21 PM
1993accordrty
Apr 12, 2004 10:41 PM
