ls turbo in ek do i need to retune!?
Old Jun 10, 2012 | 06:27 AM
V-Nonyak's Avatar
Default ls turbo in ek do i need to retune!?
title sais it all but.
i just took my ls turbo out of my eg cuz i hit a gard rail and there is no front end on the eg anymore and now put the ls turbo motor in my ek all i changed was my intercooler and my ramhorn and exhaust still using my obd1 hand command ecu but the car starts and runs very harsh and bogggy.
Old Jun 10, 2012 | 06:53 AM
justYncredible's Avatar
It's wU to the sOLdiEr!
Default Re: ls turbo in ek do i need to retune!?
if you changed to a different manifold i would imagine you would need to
assuming you had a log manifold before going to the ramhorn
Old Jun 10, 2012 | 07:24 AM
Schister66's Avatar
Man U FTW
If it starts and runs like crap, why wouldnt you retune it..? Also, if you changed anything, it needs to be retuned. It may not require much time on the dyno, but it still needs some work
Old Jun 10, 2012 | 07:39 AM
grumblemarc's Avatar
The Grumpiest
I think you knew the answer to that question before you asked.
Old Jun 10, 2012 | 11:20 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
It sounds like something else is wrong as well... Changing those few things *shouldn't* cause the starting to have greatly changed. I would assUme you did something wrong on the install/swap.
Old Jun 10, 2012 | 11:26 AM
v8killaz's Avatar
just check afr if its fine than it should be good
Old Jun 10, 2012 | 02:32 PM
egb18dx's Avatar
Might wana check spark plugs and or your fuel is the wrong oct. I know when I changed exhaust and ram horn my car never acted like that. But I still had it retuned cause I was running rich.
Old Jun 10, 2012 | 04:38 PM
TheProfessional's Avatar
Fuel Pump in the new car the same as the old? Didn't see you mention that being changed in the post.
Old Jun 11, 2012 | 04:08 AM
V-Nonyak's Avatar
Thanks for all the help guys and well I used to have a bigger ram horn and a bigger intercooler and I never thought about gas ill try to figure out what's in there and yes still useing a walbro 255 just like b4. getting tuned today at 9am ill update after
Old Jun 11, 2012 | 06:44 PM
V-Nonyak's Avatar
Went to go get tuned had bad gas dumped it out and also had a bad map sensor got fresh gas and an onny 3 bar and it ran perfect got tuned anyway hit 216hp and 199t at 10psi
EKR88
Jul 19, 2007 09:03 PM
ritalin
Jun 27, 2006 07:40 AM
solocam
Jan 8, 2006 06:59 PM
tobe1424
Dec 20, 2005 02:08 PM
fabworxs
Sep 15, 2004 05:03 PM
