AC install help
im sure there a post out there on how to do it. but if no one has one could you post detailed pics of your ac system in you integra i have a 2001 GSR and i "hope" i have all the lines i need. thanks for any help you can give me on this install.
goto any acura site and look at the part diagrams. you will find your answer there. im not doing it for you. youre lazy. additionally make sure you take it to a shop to be charged and what not because i know for a fact that you dont have all of the necessary tools to do the job. wrenches arent going to cut it. also make sure you put a NEW filter drier every time the a/c system is opened.
just google Integra AC system.
or go to honda parts online and look up the parts layout for the ac system. I reinstalled the ac in my type r like a month ago and it took me about an hour. and that was just seeing what lines went where. started off completely blind.
OH im im so lazy LMAO. dont forget you need the compressor oiled and system vacum tested before you charge it. Oh and i know for a fact your a dumbass.
Question, your GS-R did not come with A/C???
You should have the system nitrogen pressure tested, a vacuum test is done when the system is on the vacuum pump...
http://www.acuraautomotiveparts.org/...s=&view=normal 94
From: Pensacola, FL and every Court House in Louisiana
