interior lighting help?
97' auto ls integra.
cluster, gear shift, climate control/center console, parking/corner lights, these are all not lighting up. Do these tie in to eachother some how? please help, thank you
Yes., they are all on one circuit, fuse 19 - 10A, [hot when park/headlight switch is on], in under dash fuse box, the cluster and all lights that "dim" get their ground from the Dash Lights Brightness Controller, [sometimes wrongly called the dimmer switch].
Have you checked the fuse?
Use a 12V test light and probe both "test tips" on the fuse while it is still plugged into the fuse box, [with park/head lights on].
If the test light lights up on only one of the test tips, the fuse is bad, it it does not light up on either test tip, you forgot to turn on the park/head lights or the Combination Switch is bad, maybe wiring between the switch a and fuse box. 94
Mitch965
17
Feb 6, 2013 12:17 PM
kilroy79
Jan 21, 2008 05:19 AM
