EBP 2000 civic si turbo
Hey i have a 2000 civic si with 145xxx on the chassis and just over 600 on the motor and turbo setup.
Looking for cash offers or trades plus cash but must have 3200 cash on top there is still a loan on the car.
I have pictures of the build and most of the receipts
Motor
b16a2 longblock has 600 total miles on the motor and turbo setup. It has stock rods and pistons with arp rod bolts and arp headstuds.
pr3 head with itr cams and mild port job. Head was completley gone through and rebuilt.
Brand new oil pump waterpump and timing belt.
micropolished crank and balanced up to 9600 rpms.
Every seal and gasket on this motor is brand new you wont be dissapointed.
Aem fuel rail and bosch 660cc injectors. Kong intake manifold with a 70mm throttle body.
Has a act lightweight flywheel and a brand new 6 puck act clutch.
as far as the turbo setup goes its just a cast log manifold with a godspeed wastegate and godspeed super 60.
Huge FMIC and piping with a ssqv bov.
car is currently running on an HA Motorsports basemap in a p28
new blox tps
gm 2 bar map
accufab fuel psi reg.
Exhaust exits out front bumper
avid racing motor mounts with 75a bushings
still needs to be tuned but the tune is payed for(have receipt for proof)
Suspension
nex front full coilovers up front with dropzone struts and springs in the rear
itr rear sway bar
blackworks rear lca's
welded in Roll cage
Interior
Welded in Roll cage
Full interior
Aem wideband and aem tru boost
Will have stock seats in it
Wink mirror
si cluster with 40xxx on it
Im forgetting some things so any questions just feel free to ask
Make me offers i will the lower price if i remove parts.
Motor
new blox tps
gm 2 bar map
Suspension
itr rear sway bar
welded in Roll cage
Interior
Welded in Roll cage
Full interior
Wink mirror
Hummmm i was interedted but you first stated that you lost the title . Why didnt u just say u dont have the title cause of the loan instead of sayin u lost it. Any way good luck cause you might still owe more on the loan .
boostaholic
Jun 28, 2004 07:18 PM
