Keep the Sohc ZC or go Sohc vtec?????????????????
Old Oct 14, 2002 | 08:57 AM
[626]phixionEF91's Avatar
Default Keep the Sohc ZC or go Sohc vtec?????????????????
well i want a swap, i think>>>> i want somthing cheap and reliable, thats why im staying d series. i have a sohc zc, but i want more power. the z6 is fairly cheap and easy to find, but i heard the y8 is a little better. what should i do, and where can i buy a y8 with low miles?
[Modified by [626]phixionEF91, 5:57 PM 10/14/2002]
Old Oct 14, 2002 | 09:33 AM
EP3_05's Avatar
Default Re: Keep the Sohc ZC or go Sohc vtec????????????????? ([626]phixionEF91)
I would just keep the zc and build it up for boost. Changing out to the y8 imo is not worth it when you could be spending that money on building your current motor.
Malgerus's Avatar
Y8 gets my vote... that thing pulled hard in my CRX... surprised quite a few DOHC guys too, I might add
EDIT: Y8 Turbo would be UNREAL...
[Modified by 89_Y_49RIP, 6:34 PM 10/14/2002]
Old Oct 14, 2002 | 09:34 AM
Superhatch's Avatar
You need to get that ugly mug off your avtar!!
goto http://pub143.ezboard.com/bhondadseries great stuff that might help you out.
-Jake
Old Oct 14, 2002 | 11:12 AM
illusive's Avatar
I would suggest staying with yout current set-up the ZC, because if you swap in a SOHC vtec your not going to feel a big difference. They are both pretty similar in numbers. Save the money and build up your ZC. I believe you will be happier then wasting money to pull numbers(if you drag) that you can already do with this motor. Just my 2cents but do whatever makes you happy and what you think for yourself is best. Whats good for others is not always good for you.
[Modified by illusive, 8:13 PM 10/14/2002]
89ED
Oct 21, 2013 03:05 AM
4drKilla
Oct 5, 2009 07:17 PM
patrickstar
Feb 2, 2009 12:52 AM
EF_9
Apr 28, 2005 09:48 AM
civi93ex
Sep 5, 2003 10:12 PM
