hello i have got honda civic 2002 steering rack problem
hi guys need serious help i have got honda civic 2002 steering rack problem.
before i visited a mechanic the steering was playing up a bit stiff and make creaking noise when parking or uturning . i took it down to mechanic while checking for the problem the EPS light came on and steering wheel locked not able turn left or right . this prompts the mechanic to replaced the steering rack but the eps light is still coming on . i took for check up again on computer and it red out fault code .12-02 a problem with the circuit for torque sensor amp , fault code 16-01 a problem with average of voltage for torque sensor vt13 and vt16, fault code : 22-01 excessive change of vehicle speed sensor signal and last fault code :41-01 problem with the motor voltage. i was told to take it to main dealer to reprogramme the sterring rack unit with car ecu . please help
Probably should try in the ep3 and rsx model specific forums, as sedans and coupes had hydraulic power steering in North America.
Stefffff
Jul 25, 2014 11:56 AM
01PYTypeR#1140
Nov 19, 2001 09:47 AM
