Question about mil engine light on accord.
Old Jun 5, 2012 | 06:09 PM
Bladest's Avatar
Default Question about mil engine light on accord.
Hi to all i have accord made in uk year 1994 5th gen, and my engine light mil, lights almost non stop, i made diagnostic with paperclip since i have 2 pin connector,and it turns out to be error number
41 Primary oxygen sensor heater
Old Jun 6, 2012 | 01:25 AM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Question about mil engine light on accord.
Check the wiring to the O2 sensor, if it is fine it most likely the heater inside the 02 has failed. Purchase a new O2(Denso or NTK) and replace the old unit.
Old Jun 6, 2012 | 04:37 AM
glimrmn's Avatar
Agreed. I had the same problem a few weeks ago with the primary O2 sensor failing for the heater circuit in my son's 96 LX. I ohmed out the wires on the sensor side and got infinite resistance so I changed it out and that fixed it for me.
Old Jun 6, 2012 | 04:11 PM
Bladest's Avatar
So what will happen if i dont change it?
Old Jun 7, 2012 | 01:21 PM
Lost Again's Avatar
You get to look at the light. Also the car is in what some call "limp" mode meaning you don't get the best out of it...the ecu uses some default settings to keep the car going....best to get it fixed so you can enjoy the car, plus I'm not sure if you have to pass MOT or not?
Ohreally209
Oct 5, 2018 06:20 AM
bmarchio
Jun 17, 2008 06:29 AM
92integraVTECgsr
Jan 21, 2008 07:48 AM
that1mexguy
Nov 17, 2006 05:54 PM
hw3679
Jun 26, 2004 06:27 AM
