identifying ac system type
I have a 91 accord lx, and when i bought it, the ac worked good all summer, the next year it didnt work.
how do i tell if it is still r-12 or if it has been retrofitted to 134a?
Look at the A/C recharge ports. That'll tell you. R134 if I remember right has a different connector compared to R12. There's a Refrigerant kit that will tell you what you have inside your A/C system.
ok it looks like my cars system has been retrofitted, are there only two ports ? or three? i see a fitting with a blue cap on passenger side, a fitting with a red cap on driverside, should there be one more somewhere?
Pics.....pics....pics. R12 and R134a have the same number of ports. If the retro fit was done properly, the 134a ports have no threads on the outside....looks kind of like air tool fittings. R12 ports are threaded on the outside....kind of like a tire valve.
ok, i guess the car has been retrofitted, it has "air hose type fittings" threaded onto the schrader valve type fittings.
i was asking, if there should only be the two valves in total or a third somewhere?
it has been retrofitted, it still has the r12 label on the underside of the hood, but it has r-134a fittings on the ports.
ive read alot about r12 systems in accords not working good when converted to r134a, but in my car it worked very well (until the next summer , when it had leaked out.) i live in the desert near las vegas, it gets hotter than hell, but the humidity is always low in the summer.
djkurious
Aug 29, 2012 02:17 PM
mnm99
Apr 23, 2005 07:21 AM
