B18B@20psi vs. B18C-R@5psi
So this weekend st00pid just finished slapping together a turbocharged JDM B18C-R 11.0:1 motor into another EG Civic. In order to gauge its performance, he and Shami ran the two cars together from a 20mph punch. To bring you up to speed, Shami's Civic is an EG as well, weighing in at about 2400lbs running a bone stock B18B 9.2:1 motor with turbo, pushing 20psi of boost on pump gas. Best time to date is 11.8@120mph.
The latest creation is basically the same deal, but with a 11.0:1 VTEC motor pushing 5psi on pump gas. It has a thumpin *** system in it as well, and the guesstimated weight is about 2600lbs with driver. To make a long story short, the two hit it from 20mph and were neck and neck all the way to about 120mph where Shami's car was leading the ITR powered car by about a half a car. Woohoo! High CR ownz...
Both cars are running Hondata. Stock engines both (pistons, rods, sleeves, head, everything). On the LS, she's running a T04b & 440's. On the B18C-R, he's running a T3/4 60-1 with 850's. Nothing really top secret voodoo magic about it -- just good tuning.
good information. but i bet that b18 would win a heads up race on slicks.
B18B well, i was right. hehe. the b18 WOULD win.
[Modified by jinxproof99, 6:48 PM 10/14/2002]
Nice....keep in mind one car is running a 60-1 and one is running a measly t04b. Now if they were running the exact same turbo..that would have been a different case... still nice though
wild...ive raced a typeR (a real integra typeR) boost at 6psi (with a drag kit) in my turbo sohc hatchback (eg)...i was running 16psi though and i took the typeR by about 1/2 - 1 car. Although this was in colorado and the driver of the typeR said it wasnt tuning very well (doesnt everybody say that when they loose?) Never the less i wasnt that impressed with the TypeR has he spend a good $25,000 more on his car.
Never the less..i couldnt come close to a 11.8...im guessing high 12s.
Ive met Shami before and give her mad props
liam
[Modified by liam821, 12:36 PM 10/14/2002]
liam
if you wanna see what times the R engine will run in a civic coupe, just let me know...i'll "test" it for ya
[Modified by MikeMAN, 8:57 PM 10/14/2002]
Ask any racer, any real racer. It doesn't matter if you win by an inch or a mile; winning's winning.
liam (goes and puts on his flame suit)
Pics for you (text taken from clubsi ..what st00pid said)
98 JDM ITR swap
Clutch masters stage 5
Hondata stage 3b
MSD 85lbs/hr injectors
TiAl BOV
TiAl 35mm Wastegate
REV Hard cast iron manifold
GReddy Profec B w/ remote switch
Golden Eagle block guard
ARP head studs
AEM fuel rail and regulator
Autometer EGT and boost gauge
Autolink fuel pressure gauge
JG cam gears
E-Cutout
GReddy Exhaust
Thats all I can think of. So far we have the car running at 5psi and I would guess its making about 270whp.. I will dyno it soon and get you guys all the numbers.. The car retains AC and power steering. Also the E cutout is reall fun to play with...
98 JDM ITR swap
Hondata stage 3b
TiAl BOV
TiAl 35mm Wastegate
ARP head studs
JG cam gears
E-Cutout
GReddy Exhaust
