hunting idle on 2000 accord v6
Yeah the IACV is a good place to start. Also check for vacuum leaks. If neither of those are your issue it could also be an air bubble in your coolant. In my case it was caused by a gummed up throttle body. I had to take mine off and intensively clean it with tb cleaner and a toothbrush, although if that is your problem you may not have to take yours off.
Here is a write up
Here is a write up
causes for hunting idle or surging idle on honda and acrua. air in cooling system, iacv, fitv, leaking intake gasket, vacuum leaks. gunked up throttle body
