Help: D series tranny ?'s (disassembly)
ok, here am trying to get this damn tranny apart, and all i can do is get the case to come about 1in apart ....WTF?? i need to know what holds this thing together, i have pulled every sensor, and every plug, i remember hearing something about a clip that i need to take off before it comes apart, but i CANT FIND IT!!!!
thanks in advance
brian
thanks in advance
brian
There is a spring clip that holds the countershaft that you need to release as you sperate the case. It is behind a hole in one end of the tranny that you remove with a 3/8" ratchet in the square.
You will need a snap ring pliers and a lot of patience.
Randy
Randy
ok, i have seen that snap ring, but that looks like a bitch to get to.. all that is there is two little tabs on each end of the ring... damn this is going to be real fun...
Thanks RGAZ,
brian
Thanks RGAZ,
brian
Thanks RGAZ,
brian
Thanks RGAZ,
brian
92EG8
Nov 29, 2007 01:56 PM
