Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Civic SI ´07 aceleration issue/hiccup
Old Jun 5, 2012 | 11:26 AM
danielfabricio's Avatar
Default Civic SI ´07 aceleration issue/hiccup
hello guys, im from brazil, i have a civic Si 2.0 16 2007 - vtec engine...
my car have the cat. removed; cold air intake and unichip, everything was working very fine. In the last weeks, a fail/issue in the aceleration appeared.
If I acelerate the car from zero and making the engine rotate 8000rpm at the gear change, everything works fine.
but if I drive at second, third or higher gears, at low rpm, like 2000rpm and put the pedal to the metal (full throttle), the car in +- 4000rpm to 5000rpm stars to fail, like hiccup...
i changed the sparks, cleaned the injectors, verified all the eletrical conectors and the fail/issue continues...
somebody can help me?
sorry by the bad english
Old Jun 6, 2012 | 11:01 AM
HRsi-dan's Avatar
Default Re: Civic SI ´07 aceleration issue/hiccup
Did you get it tuned? I used to have what seems like the same issue when I had my old Fujita SRI where I could feel a hiccup if I got on it at low RPM's.
I'm not sure what the "Unichip" is (sounds like a universal tune/reflash), but I'd suggest getting Flashpro and a tune or e-tune.
peterjadams
10
Aug 20, 2009 04:54 PM
Si87
50
Jul 2, 2009 03:29 PM
Messiah62
Mar 27, 2009 02:03 PM
Falcameno
16
Mar 12, 2008 08:52 PM
NONKonformyst
20
Jan 26, 2003 05:24 PM
