94-95 vs 96-01 Integra Gs-R Water pump Difference.
Greetings H-T
Im here with couple of question, I would like some details ,about water pumps between the 94-95 vs the 96-01. I've done my google research but havent came up with a solid answer. Im sure both water pumps perform the same (22t), I've read that the the 96-01
Is a bit difference as it provides 2 slot/ guides for the obd2 timing cover. Is this true, I am not sure?
I own a 95 integra GSR and is about do for maintenance, I would like to know, what will I have to do to install the 96-01 water pump on my 95 integra. If needed I will purchase a obd2 lower timing cover. I just want to confirm, as nobody likes to spend money on the wrong parts.
If you can provide pictures between the 2, that would be greatly appreciated.
Thank you!
Thank you!
