Garage Cleanout! Lots of S2000 & EK 99-00 Civic Parts
Old Jun 4, 2012 | 07:44 PM
MrJDM_'s Avatar
Default Garage Cleanout! Lots of S2000 & EK 99-00 Civic Parts
Item: MASSIVE S2000 & EK CIVIC PARTOUT
Price: Varies
Contact: 954-600-6766 TEXT
Item Description: S2000 & EK Civic Parts
Photos: Everything is listed first then followed by pics.
S2000 Parts
1. BB Trunk Lid SOLD
2. AP2 Door Panels SOLD
3. AP2 Headlights w/ Bulbs + Ballasts SOLD
4. AP2 Steering Wheel
5. Black Face AP2 Bezel
6. AP2 Cluster
7. AP2 Radio Door
8. AP2 Exhaust Tips
9. BB Hood SOLD
10. AP2 Rear Bumper
11. Passenger Fender SOLD
12. Driver Fender SOLD
13.OEM Air Box w/ Filter
14. Pass + Driver Seat Belts
15. S2000 Sun Visors
16. Driver Side Roll Bar Plastic SOLD
17. Passenger Side Roll Bar Plastic Cover SOLD
18. Driver + Passenger Roll Bars
19. Passenger Side Air Bag
20. Windshield Wiper Cover
21. AP2 Center Console Leather
22. AP2 Crash Beam
23. AP2 Headlight and Windshiled Switches
24. Passenger Side Cargo Net
25. Driver & Passenger Kick Panels
26. Glove Box
27. AC Plastic Cover
28. Behind Seat Plastic Cover
29. Driver + Passenger A Pillars
30. Hood Prop
31. Subframe Strut Bar
32. Windshield Wiper Motor
33. Windshielf Fluid Resivor
34. Gas Cap
35. AP2 Radio W/ Code
36. Radiator Support Strut
37. Full Trunk Carpet Set
38. Front Subframe
39. Front Lower Control Arms
40. Engine Splash Guard
41. Battery Tray
42. Brake Booster
43. Brake Master Cylinder
44. ABS Pump
45. AP2 Drive Shaft
46. S2000 Under Dash AC Units SOLD
47. Driver + Passenger Front Hub
48. Driver + Passenger Upper Control Arms
49. Passenger Side AP2 Splash Guard
50. Brake and Clutch Pedals
51. OEM AP2 Header
52. 02 Sensor
53. Starter
54.Starter Harness
55. Charge Harness
56. Engine Bay Harness
57. Floor Harness
58. Fuse Box Harness
59. Under Dash Fuse Box
60. OEM Shocks and Springs
61. AP2 Drive Shaft SOLD
62. Jack Holder
63. AP2 Differential SOLD
64. AP2 Axles SOLD
65. AP2 Front Diff Mounts $40 Each
66. AP2 Rear Diff Mounts $40 Each
67. AP2 Rear Sway Bar $115
68. AP2 Passenger Hub Complete $125
69. AP2 Driver Hub Complete $125
70. AP2 Rear Upper Control Arm Passenger + Driver $100 Each
71. AP2 Rear Lower Control Arm Passenger + Driver $100 Each
72. AP2 Rear Subframe $250
73. AP2 E Brake Lines PAssenger + Driver $75 Each
74. Under Dash Harness
75. Trunk Liner
76. Windshield Liner
77. Behind The Seat Plastic
78. AP2 Headlight Brackets AP2 Flywheel AP2 Heatshield
79. OEM Driver Axle
80. OEM Springs
81. OEM Bulbs
82. AP2 Driver Side Mirror
83. 06+ ECU + Ignition
84. AP2 Center Console Black Face
85. AP1 Climate Control
86. Door Panel Shells
EK Civic Parts
1. OEM Catalytic Converter $120
2. Driver Side A Pillar $25
3. Passenger Side A Pillar $25
4. Passenger Side Door Sill $20
5. Driver Side Door Sill $20
6. Driver Side Kick Panel $15
7. Light Cover $7
8. Driver Side Coat Hanger $12
9. Passenger Rear Plastic $60
10. Driver Rear Plastic $60
11. SRS REEL $50
12. EK Steering Column W/ Key $100
13. EX Headliner Light $17
14. D Series Heat Shield $25
15. D Series AC Bracket $40
16. D Series Tranny Torque Bracket $35
17. D Series Power Steering Pump $40
18. EK Hood Release $15
19 Duralast Battery $45
20. EK Crash Beam $50
21. OEM Jack Set $30
22. Trunk Plastic $15
23. Under Dash Plastic $15
24.Shifter Plastic $15
25. Center Plastic $15
26. Passenger Kick Panel $15
27. Steering Column Cover $20
28. Inner Door Dash Plastic $15
29. Engine Bay Fuse Box Cover $10
30. Engine Bay Fuse Box $30
31. Gauge Cluster Bezel $15
32. EK Center Console $40
33. Power Mirror Switch $20
34. Sunroof Switch $20
35. Cluster Light Switch $10
36. Cruise Control Switch $15
37. Pass AC Vent $10
38. Tranny Bracket + TQ Mount $45
39. EK Airbag Set $80
40. EK Glove Box $30
41. EK Driverside Mirror $25
42. EK Passenger Side Mirror $25
43. Battery Tie Down Set $15
44. Coolant Resivor $10
45. Power Steering Resivor $15
46. EK Gas Tank Lid $15
47. AC Condensor Bracket $10
48. Coolant Resivor Bracket $10
49. Battery Tray Plastic $5
50. Battery Holder Bracket $20
51. 99-00 EK Cup Holder $40
52. OEM EX VTEC AirBox System COMPLETE $125
53. EK Sway Bar CONVERSION W/ LCA and Sway Bar $175
54. EK Passenger Rear LCA $20
55. EK Driver Rear LCA $20
56. EK Driver Headlight Bracket $20
57. EK Passenger Headlight Bracket $20
58. EK Mirror (Great Shape) $25
59. Automatic Shifter w/ Button $15
60. EK Headliner $65
61. EK Sun Roof Assembly $80
62. EK Sun Roof Motor $25
63. EK Dash (Excellent Shape) $100
64. EK Antennae $25
65. EK Side Skirts $80
66. EK Rear Seat Belts $25
67. EK Back Seats $45
68. EK Brake Booster $40
69. EK Brake Master Cylinder $30
70. Fuel Filter Bracket $15
71. EK Single Cam Tranny Mount $35
72. EK Single Cam Tranny Bracket $35
73. Brake Prop Valve $40
74. Tranny Ground $5
75. EX Hub Cap (Have 2 $20 Each)
76. Windshield Wiper Motor $50
77. Turn Signal and Windshield Wiper Switch Combo $30
78. UNCUT Wiring Harness $150
79. 99 - 00 Civic Climate Control Conversion $150
80. Driver Side Power Window Motor $30
81. Driver Side Window Regulator $30
82. Passenger Sider Window Power Window Motor $30
83. Passenger Side Window Regulator $30
84. Under Dash Main Harness $150
85. EK Gauge Cluster Harness $25
86. OEM Fuel Pump $25
87. Driver Side Windshield Wiper $20
88. Passenger Side Windshield Wiper $20
89. EK Cruise Control Switch $10
90. OEM EK Steering Wheel $25
91. Automatic EX ECU $65
92. Dash Bracket $80
93. OEM Radiator $25
94. OEM Radiator Fan $15
95. EK Spare Tire $50
96. EK Cluster $50
97. EK Front Bumper $65
98. EK Rear Bumper $65
99. EK Trunk Lid $100
100. Honda Emblem $10
101. Civic Badge $10
102. EX Badge $5
103. Under Bumper Splash Guard $25
104. Single Cam Axle Set $100 ($65 Each)
105. Pioneer Radio W/ Harness $65
106. EK Coupe Trunk Cardboard $35
107. FULL AC KIT FOR YOUR 99-00 EK (Every line, Compressor, Condenser, fan, etc.) $250
1. BB Trunk Lid $300 Shipped
2. AP2 Door Panels $350 Shipped
3. AP2 Headlights W/ Bulbs + Ballasts $1000
4. AP2 Steering Wheel $350
5. Black Face AP2 Bezel $150
6. AP2 Cluster $300
7.AP2 Radio Door $50
8. AP2 Exhaust Tips $100
9. BB Hood $350
10. AP2 Rear Bumper $300
11. Passenger Fender $300
12. Driver Fender $300
13.OEM Air Box w/ Filter $100
14. Pass + Driver Seat Belts $80 Each $150 Pair
15. S2000 Sun Visors $60
16. Driver Side Roll Bar Plastic $50
17. Passenger Side Roll Bar Plastic Cover $50
18. Driver + Passenger Roll Bars $60 each $110 for the set
19. Passenger Side Air Bag $150
20. Windshield Wiper Cover $55
21. AP2 Center Console Leather $125
22. AP2 Crash Beam $120
23. AP2 Headlight and Windshiled Switches $60 for the Set $37.50 Each
24. Passenger Side Cargo Net $30
25. Driver & Passenger Kick Panels $35 Each both for $60
26. Glove Box $50
27. AC Plastic Cover $40
28. Behind Seat Plastic Cover $20 Each
29. Driver + Passenger A Pillars $45 Each
30. Hood Prop $35
31. Subframe Strut Bar $50
32. Windshield Wiper Motor $65
33. Windshielf Fluid Resivor $40
34. Gas Cap $40
35. AP2 Radio W/ Code $65
36. Radiator Support Strut $60
37. Full Trunk Carpet Set $250
38. Front Subframe $180
39. Front Lower Control Arms $100 Each $195 for the pair
40. Engine Splash Guard $100
41. Battery Tray $30
42. Brake Booster $60
43. Brake Master Cylinder $50
44. ABS Pump $150
45. AP2 Drive Shaft $125
46. S2000 Under Dash AC Units $150 Each
47. Driver + Passenger Front Hub $150 Each COMPLETE (minus upper control arms)
48. Driver + Passenger Upper Control Arms $65 Each $100 For Both
49. Passenger Side AP2 Splash Guard $65
50. Brake and Clutch Pedals $57.25 Each
51. OEM AP2 Header $100
52. 02 Sensor $45
53. Starter $75.00
54.Starter Harness $25
55. Charge Harness $30
56. Engine Bay Harness $175
57. Floor Harness $175
58. Fuse Box Harness $175
Old Jun 4, 2012 | 07:45 PM
MrJDM_'s Avatar
Default Re: Garage Cleanout! Lots of S2000 & EK 99-00 Civic Parts
59. Under Dash Fuse Box $50
60. OEM Shocks and Springs $250
61. AP2 Drive Shaft $100
62. Jack Holder $75
63. AP2 Differential $375
64. AP2 Axles $125 Each $225 Pair
74. Under Dash Harness $150
75. Trunk Liner $40
76. Windshield Liner $50
77. Behind The Seat Plastic $50
78. AP2 Headlight Brackets $50
AP2 Flywheel $50
AP2 Heatshield $50
79. OEM Driver Axle $115
80. OEM Springs $45
81. OEM Bulbs $40 Each
82. AP2 Driver Side Mirror $100
83. 06+ ECU + Ignition $250
84. AP2 Center Console Black Face $65 (Switches included)
85. AP1 Climate Control $65
AP1 Climate Control (Excellent Condition) $85
86. Door Panel Shells $85 Each or $150 for a pair (Black Shell SOLD!)
Civic
EK Front Bumper $60
EK Headlights $60
EK Hood 99-00
7. Light Cover $7
11. SRS REEL $50
MrJDM_'s Avatar
64. EK Antennae $25
Old Jun 10, 2012 | 06:51 PM
integramic's Avatar
I'm interested in some of the parts but I have to see if they fit ap1 also.
Old Jun 10, 2012 | 07:31 PM
Mister Jew's Avatar
What's the vin for the ap2?
Chubakon
May 19, 2016 06:21 AM
b18bc3po
Jun 20, 2013 11:34 AM
MrJDM_
Jan 9, 2013 08:50 PM
bzyrice
Feb 18, 2008 06:33 PM
bzyrice
Dec 21, 2007 09:11 AM
