New info for B-series guys looking for cheap synchros
Seagull Management
I'm not sure if anyone ever made this observation before, but '92 - '00 D-series 1st/2nd synchros are the same as B16A Hydro 3rd/4th synchros. Personally tested/confirmed.
Why does this matter? You can buy a '92 - '00 D-series trans (especially if there's something wrong with it) for under $40 most of the time) the 1st gear synchros are almost always good.
The trans I was working on is a Y21 B16A with OEM 14 bolt viscous LSD if it matters.
Seagull Management
Seagull Management
I'll concur 88-00 SOHC FWD D 1/2 are the same as BVTEC 3/4. Figured this out sometime in 06, someone else probably sooner than that. Good info for people to know though, add it to the FAQ.
While neat information, you can source a brand new brass synchro for the same price as the trans you mention, it'll be 100% new guaranteed, and you didn't have to put any labor and time into the tear down of the trans and countershaft. For me, not quite worth it IMO. LOL
Aren't the 3/4 D-series 96-00 EX synchros the same as the B-series 5th, too? Or is it any non 96-00 EX 3/4 synchro? I don't mess with SOHCs too much so unsure but I thought there was more interchangeability than just this.
Seagull Management
No they're smaller, I checked. Also all 3rd/4th D-series synchros are the same. That's one of the nice things about them. 1st and 4th synchros are usually good, get two trans and you have enough synchros, sleeves and hubs are all the same too between trim levels.
IEATLINT
Mar 4, 2004 11:37 AM
