Transmission & Drivetrain Gearboxes, Differentials, Clutches
used 98' spec vs. new 96' spec type r tranny?
Old Jun 4, 2012 | 02:17 PM
ctr_dru's Avatar
Default used 98' spec vs. new 96' spec type r tranny?
So I have a questions for you guys, i have a 92 eg hatch w/ 96 type r swap... now the tranny went out and i have 2 good options so far... like the title says used 98' type r tranny which im getting for 1300 shipped or a new 96 type r for 1800.... i still need to get a clutch too any recommendations?
Old Jun 4, 2012 | 05:47 PM
type_r_ek's Avatar
Default Re: used 98' spec vs. new 96' spec type r tranny?
i have a 96 itr trans in my ek with 96 itr swap, id reccomend a b16 trans (cheaper) and an ls 5th, going down the road at 60 at 4k pisses me off, and for a clutch either oem itr clutch or exedy stage 1
Old Jun 4, 2012 | 06:06 PM
doood's Avatar
been there done that
the 98 spec has better ratios. b16 1-3 and gsr 4-5 with the 4.7fd. get that one.
Old Jun 5, 2012 | 04:59 AM
94EG8's Avatar
Seagull Management
B16 trans (other than CTR) has a smaller diff, no LSD, only 2nd gear has a double cone synchro, etc. In other words it's cheaper for a reason.
Old Jun 5, 2012 | 01:16 PM
ctr_dru's Avatar
yes i also have the option of a guy thats willing to sell me a gsr case w/ b16 1-4 and 5 gsr and thats w/o lsd.... i knw that would be great for highway but wouldnt a 98' spec be the same or better since it does have lsd plus it has 4-5 gear of gsr correct me if im wrong
Old Jun 5, 2012 | 03:40 PM
doood's Avatar
the 98 spec would have higher cruising rpms because of the shorter final drive
98 itr = 70mph @ ~3700rpm
gsr = 70mph @ ~3400rpm
play around with this and see what you'll be at: http://www.teammfactory.com/gear-calculator
Old Jun 5, 2012 | 04:40 PM
94EG8's Avatar
Seagull Management
Originally Posted by doood
the 98 spec would have higher cruising rpms because of the shorter final drive.
It's actually about the same. Early ITR has shorter (B16) 4th and 5th gears. 98+ has a shorter final drive with longer (GS-R) 4th and 5th gears. Cruising RPM is a wash. Acceleration from 1st through 3rd is where the '98 spec ITR trans really shines.
Old Jun 5, 2012 | 06:12 PM
ctr_dru's Avatar
is there any good aftermarket ones i dont mind paying a bit more just would like a warranty esp since its my dd
Old Jun 5, 2012 | 06:28 PM
ctr_dru's Avatar
so thinking of going custom i mean its my dd and goin to try to keep it as long as i can just wanna knw any good places out ther w/ warranty that is a must if im paying a pretty penny... and what would be the best gear ratio ..... i was thinking itr 98 spec for 1-3, grs 4, and Ls 5 th would that work is it possible kinda noob to this tranny stuff ...HELP
Old Jun 5, 2012 | 06:37 PM
doood's Avatar
was going off what the gear calculator showed. i do agree that a few rpm difference cruising isnt a big deal. for me anyway.
KPowerSquadron
Nov 9, 2010 03:09 PM
redDAinteg
Aug 12, 2008 10:30 PM
hayabusa750
Mar 16, 2007 07:54 PM
SilverDc2
Sep 22, 2003 03:35 PM
