98 civic offset
Old Jun 4, 2012 | 11:21 AM
98EJ7Y8's Avatar
Icon2 98 civic offset
what is the max offset i could use without any spacers or fender rolling on my 98 hx ?? i have factory alignment, with eibach sportline springs on kyb gr-2 struts ..
i would like to get a decently aggressive look , i was thinking maybe +30 would be alright to run ?
Old Jun 4, 2012 | 11:28 AM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
Default Re: 98 civic offset
I wouldn't go lower than a +30 on a 7 inch rim. You can probably fit a bit bigger in the front, but the back will need to be rolled to get any wider.
Old Jun 4, 2012 | 12:16 PM
98EJ7Y8's Avatar
thanks i had 17x7.5 on before not sure of the offset but they fit pretty good .. my plan was to get a 16x7 +30 . so that works out pretty good. also how much work would need done to put a set of spun supamesh +20 on the car ?
Old Jun 4, 2012 | 03:35 PM
98EJ7Y8's Avatar
i seen the post of some users arguing over offset and fender rolling .. i just need to know will a 16x7 +30 fit without any fender rolling or camber adjustment ?? i can deal with the camber myself . but i wont get my fenders rolled .. or would a +38 be a better fit and less hassle with all the other junk
Old Jun 4, 2012 | 04:00 PM
2LEM1's Avatar
I like to party
Community Builder
Each car will be different due to varying degrees of camber from lowering. You can most likely get away with 16x7 +30 with no camber and not rolling fenders. +38 will clear for sure.
Old Jun 4, 2012 | 04:31 PM
98EJ7Y8's Avatar
thanks for making it pretty clear without all the others arguing .. im prob an inch and a half from the ground maybe a little more .. but i have all the adjustable trailing arm arms .. so camber is no biggy , but the front is my concern thats why i wanna make sure i get something decent enough to look agressive without or very little adjutment that will fit the front also that i wouldnt have to adjust .. sorry for all the questions just wanted to get a clear answer without 20 people all having a different answer
98EJ7Y8
22
Oct 22, 2019 10:30 PM
95Sedan
15
Jul 2, 2013 03:18 PM
PR_purpleDb7
Jan 29, 2009 06:52 PM
ievaq8
Jan 29, 2009 01:21 PM
juice91si
Mar 21, 2006 06:59 PM
