Installing 94-95 AC compressor on 92-93 system
Old Jun 3, 2012 | 04:55 PM
JohnnyEF's Avatar
Default Installing 94-95 AC compressor on 92-93 system
I plan on installing a new 94-95 AC compressor on my 93 civic cx. The system has already been converted to r134a. The reason I plan on getting a 94-95 compressor is because the sanden compressor is cheaper for the 92-93. I had heard the 94-95 compressor won't fit with 92-93 lines on one side not sure if high or low side? Anyone have experience with this? I need to know what new lines I need buy to make this compressor work with my 92-93 system. Hopefully I can keep my condensor and receiver.
Old Jun 3, 2012 | 07:11 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Default Re: Installing 94-95 AC compressor on 92-93 system
The fittings going into the compressor are the same. It is the hard lines going to firewall that are different. I have a 94 that had ac and I used a 92 ac condensor.
Old Jun 3, 2012 | 07:51 PM
JohnnyEF's Avatar
Is that a typo you said you used a 92 ac condensor? Did you mean compressor?
Old Jun 3, 2012 | 09:49 PM
No all of my ac system is 94 except the ac condenser fan. I had some r12 lines that connected to the r134 compressor but not at the firewall.
Old Jun 4, 2012 | 12:17 AM
JohnnyEF's Avatar
Confused my question was does the two 92-93 r12 lines fit the 94-95 r134a compressor without issue. Not sure what the condenser has to do with it.
Old Jun 4, 2012 | 07:58 PM
JohnnyEF's Avatar
ttt
Old Jun 5, 2012 | 06:34 AM
94EG8's Avatar
Seagull Management
No they don't.
Old Jun 6, 2012 | 08:42 PM
JohnnyEF's Avatar
Originally Posted by 94EG8
No they don't.
Do you know if its the hi or low side?
Old Jun 7, 2012 | 03:16 AM
94EG8's Avatar
Seagull Management
Both IIRC.
samson_420
May 20, 2021 03:29 AM
baybay
Aug 26, 2018 02:39 PM
Davidss
Jul 16, 2009 05:51 AM
Draggin99Si
Dec 29, 2006 05:36 PM
