honda civic 2000 loses power when temperature goes up help!
i need some advice i was wondering if anyone could help me out i have a 2000 Honda civic ex i'm losing power as my car's temperature goes up. only does this when the temp goes up. when the car is cold it will take off good and run smooth.. then the car warms up and down goes the performance
the motor sounds like its stressing
no CELS
also starting the car isn't so smooth i have to try at least 3 to 4 times in a hot day.. here's what i have done so far
Adjust the timing belt, bought a new fuel pump, sparkplugs, new distributor, im all out of ideas help!
the motor sounds like its stressing no CELS
well i decided to use a OBD2 scanner anyway and to my surprise i got 3 codes
po301
po302
po300
any help??
po301
po302
po300
any help??
Well those are misfire codes which explains your power loss,and if your losing power/misfiring when the engine overheats....all signs point to head gasket failure
The burning of coolant is causing the misfire/power loss
i checked the codes everything has been ruled out and i think it might be
the catalytic converter getting a straight pipe installed tomorrow see if that works
maybe knock sensor is bad. IDK look up bad knock sensor on Google, Worth a look IMO. Converter is a possibility. Would temp have an effect on power though if it is the converter. maybe through expansion closing the honeycomb.
You have a misfire in cyls 1 and 2. That has absolutely nothing to do with your cat. When was your last full tune-up?
well i did a little of thread reading and some pointed at the cat
not sure what to do at this point might check out what hondad6 suggested
Let the engine idle to warm up, then turn it off and test the plugs. Also, check your injectors.
You have a misfire. A cat isn't going to fix that.
its propbably a warped block idk i replaced the head gasket 3 times already so it could be.. thanks for the help everyone but i decided to just to sell it, not going to spend anymore time and money on a d16
