B-SERIES Blocks/Super Parts List
Names Zack
Location...Smithfield,PA
Phone #724-984-2168
-WILLING TO Shipp Out Anything...You Pay Shipping tho
PAYPAL READY
Parts I Will Trade For
~B-SERIES HYDRO TRANNYS GOOD OR BAD
~B-SERIES Hydro 5 Speed Starter
~AEM UEGO WIDEBAND/WITH GAUGE
-ZEX Nitrous Kit...Dry Kit...Control Box,Stainless Line For Purge Kit&Stainless Line To 75 Shot Nozzle,ZEX HONDA Nitrous Plugs 1,000 Miles,Bottle Brackets,10lb Bottle 3/4 Full,Has Switch and Button,Harness to Run the Box(Brain)....Included The Stainless Feed Line From Bottle To Box ....But its Broke...i priced and they was 45.
ASKING $335.00
-Wiseco 81mm B16/B18a,b 9:8-10:0 Depends What Head u Use...3,500 Miles on Pistons....
Includes (4) Brand New Sets of Wiseco Race Rings...$360.00 Firm PENDING SALE
-GREDDY Profec-B Auto Timer...Turbo Timer...With Plug N Play Civic/Integra Ignition Wires..$65.00 Shipped
-F23 ULEV VTEC SOHC HEAD...Complete. $130.00 or $170.00 Shipped
INCLUDES
All Valve Train/Cams
Valve Pan Cover
Vtec Solenoid
Distributor...Needs Rotor Button/Cap
-D16A6 Non Vtec Head...was all rebuilt 4k Miles ago...shaved .20...New Valve Stem Seals....Really Clean Has Non vtec ZC Cam In it....$100.00
D16Z6 Head SOHC VTEC $45.00 (Great Head if you want to complete build valve train On a SOHC VTEC Motor And Keep ur head on ur car for Spare
includes
Top Valve Train
Valve Pan Cover
NEEDS:VALVES/SPRINGS/RETAINERS/VTEC SOLENOIDOther Parts
-AutoMeter Carbon Fiber....(EGT) Exhaust Gas Temp Gauge...Onlything this Needs is a Small Fitting to Go Over by where it Screws Into Manifold Or Exhaust...I might even have One if not there Like $2 bucks Asking $75,00
-D16Y7 Non-Vtec Head....110,000 Miles...Has a Regrind Cam in it...Was Lopy And Ran Like A Beast...Was Told by a Buddy i bought it off of Has a Delta 262 or 272 In Not 100%...But $100.00 You Cant Beat the Price for Head/Valve Pan Cover
-92-95 Civic Wiper Motor ...$30.00
-OBD1 P07 5 Speed Ecu...has a burnt injector driver #1&4 is same Resistor And here Is Pics of the problem...a Easy Fix...I just dont mess with ecus.....$40.00 sHIPPED
-OBD1 P06 5 Speed Virgen Ecu....$65.00 Shipped
-OBD0 PM6 88 Civic 5 Speed Ecu....$50.00 Shipped
-OBD2 P2E ECU I Have Auto And Manuel.....$40.00 Shipped AUTO $50.00 Shipped Manuel
-92-95 Civic SI OEM Fuel Pump/Complete Drop in Assembley...I Replaced it 2 Years Ago...Only Has 30k Miles Tops....Includes Everything in Picture.....$60.00 Shipped
-92-95 Civic EX Power Folding Mirrors....Great Shape...One is OEM Black &Other is Primer Grey....$25.00 Shipped Each
-B-SERIES HYDRO ACT XTREME Stage 2 Pressure Plate...Only.....Has 5,500 Miles....$45.00 Shipped
-B-SERIES HYDRO Brand New OEM Replacement Pressure Plate. ONLY...$50.00 Shipped
-D15B2 SOHC Non Vtec...Cable..Brand New OEM Replacement Pressure Plate...$35.00 Shipped
-D15B7 OBD1 5 Speed P06 ECU....$70.00 Shipped
-94 Integra Coupe 3rd Brake Light ....$20.00 Shipped
-D16Y7 OBD2 AutoMatic P2E ECU...$45.00 Shipped
-92-95 Civic EX Power Steering Rack...81k Miles..Great Shape..No Tie Rods Inner or Outer...$45.00
-92-95 Civic Full Power Steering Set Up...Bracket/Pump/Lines/Cooler.....$80.00
-92-95 Civic 4 Door Trunk Lid....No Rust...Just has alot of Spray Paint...Sand it Down and will be Good...$35.00
-94 civic ex SedAN MINt oem tail lights $45.00
-B18A1 OBD0 Intake Manifold....Its Bare,,,$25.00
-92-95 Civic EX Black Dash...Has Passenger Side Air Bag...Dash is Mint....No Gauge Cluster/Cluster Trim..in 8/10 Condition Mayb Better..$80.00
-93-94 Civic CX Black Dash...No Air Bag...No Cluster/Cluster Bazel Cover...In 6/10 Condition
-92-95 Civic EX Steering Colum/Ignition/With Key... Black Steering Wheel...But Air Bag is Poped.Also Has Windshield Wiper Switchs to..Tilt Wheel Also...$90.00
-93 Civic Sedan ABS Computer for Trunk wITH Mounting Cage $45.00 Shipped
-B18C1 OEM KNOCK SENSOR...$45.00
-Brand New Ebay $110.00 Header....For 2.0 Non Turbo Eclipse/Talon...Has Flex Pipe....$55.00
-92-95 Civic Main Relays....$25.00 Each
-B18A1 OBD0 Intake manifold $30.00
-92-95 Civic Dash Cover...nOT Climate control...$15.00
-B16A2 EM1 DOHC VTEC CAM SHAFTS...56K Miles...Great Condition...$55.00
-94 Integra Dash clock $15.00 Shipped
-92-95 Civic Grey Center Console From Cup Holders to E Brake...Mint Condition...Only thing Cup Holder Case is Black $35.00
-91 Integra Coupe OEM Front And Rear Mud Flaps...Rears Say Integra....$50.00
-H22 &F22 Fuel Rails $25.00 Shipped Each
-ZC AXles and half shaft
-91 Integra LS Coupe Front Windshield...Mint No Cracks....$100.00 Firm
-91 Integra LS Coupe Hood...Good Shape 2 Dents....$75.00
-91 Integra LS Coupe Rear Hatch/With Glass/3rd Brake Light/Wiper Motor....Great Condition No Rust...Maybe A dING Or 2....$95.00
-91 Integra LS Coupe Driver Side Fender....Has DOHC Trim....$40.00 (ALSO HAVE Driver&Passenger Side Inner Fender'S Plastic Pieces for 91 Teg....$25.00 Each or both for $45.00
-91 Integra Ls 5 Speed Gauge Cluster Mint Condition....$45.00
-92-95 Civic CX 5 Speed Gauge Cluster...No Tach...$25.00
-90 CRX DX Rear Drum Brakes/-brake Cables....NO LCA/TOE ARMS....$50.00 For Both Sides
-96-98 Civic Driver Side Head Light...Needs a Lil Plastic-X And It Will Clear Up Nice $12.00
-96-00 Civic 4 Door..Side Skirts....Was Painted While(Rattle Caned...Half is Coming Off So will Be Easy to Strip...$55.00 Both
-91 Integra LS Head Lights....Both Driver&Passenger Side...Glass&Plastic Lights...Light Bulbs....No Corner Lights...But these Are Great Condition...$75.00 4pc and cage Complete
-92-95 Civic EX ABS ECU Control Unit That Bolts In Trunk...Has Bracket to $45.00
-D15B8 Civic CX 8 Valve Non-Vtec Head Complete...D15B8 OBD1 Intake Manifold....Complete...Great Gas Mileage Head....Great Condition&This Head Can Be Put on a 16 Valve D15B7 BLOCK....$135.00 For Head&Intake Manifold
-96 Civic Tan Glove Box/Center Console...And Couple Odds and ends...$25.00 Takes it All
-94 Integra Coupe Rear Wiper Motor/With Wiper Arm....$20.00 /94 Integra 3RD Brake Light $10.00
-94 IntegraB18B1 LS Automatic Transmission/Torque Converter/Mount/...115,000 Mile's....Fluids That Came out was Clean...$175.00 pICKED UP
-94 Integra P75 Auto Starter....$30.00
-91 Integra LS Coupe Rear Bumper....6/10 Condition...$40.00
-91 Integra Driver&Passenger Power Mirrors...$30.00 For Both
-92-95 Civic EX OEM Front Struts&Springs...Good Condition...$50.00 For Both
-D16Y8 OBD2 Altinator $35.00
-92-95 Civic Cruise Control Unit's.....$20.00 Each
-91 Civic SI Heater Controls....Heater Core Box/Fan Motor/Spacer....All 3 For $90.00
-92-95 Civic DX Climate Control Unit....$35.00
-92-95 Civic DX GREY Steering Wheel/Air Bag....$40.00
-96 Integra GSR Black Passenger Side Airbag...$35.00
-88-91 Civic Steering Colum Cover...$20.00 Shippped
Lower Steering Stem Cover $12.00 Shipped
-95 Civic EX Auto Cruise Control Unit...$30.00 Shipped
-96 Integra GSR Tan Leather Front Seats....Passenger Side is Mint....Driver Side Needs Redone....I was going to get Redone Black Leather....$110.00 Picked up
-96-98 Civic OEM Front Grill...$15.00
-91 Integra LS Steering Colum....Tilt Wheel..No Igniton or Steering Wheel $45.00
-92-95 Civic EX 5 Speed Motor Harness....Has Vtec Wires There But Plugs Were Cut off & OXYGEN Sensor Wires Are Extended...$75.00 Shipped
-88-91 Civic OEM Battery Trey....$10.00
-88-91 Civic Bobby Brown Glove Box...$15.00
-F22 or H22 I Will Check...Intake Manifold Flange So u can Make Either ITBS OR Custom Manifold...$20.00 Shipped
-92-95 Civic Coupe Wings West Polyurthane Front And Rear Bumper....Rear Not Pictured...Both Have Mesh But Front Center...Great Condition No Cracks...Some Scraps On bottom..I dont Have Skirts Eks Looked good with it....$200.00 For Front And Rear
-08 Honda 450R Stock Gas Tan...$20.00
-95 Integra LS Map Sensor For Top of Throttle Body...$35.00 Shipped
97 Integra GSR Map Sensor...With Plug/Pigtails...$45.00 Shipped
Jackson Racing SuperCharger Solenoid For i think Water/Meth Injection$40.00 Shipped
-Alot of Random Stuff i Dont feel Like Typing So If ur interested in Something PM ME
-92-95 Civic SI Ecu Plugs....Alll 3....$25.00 Shipped
-F22B7 Non Vtec Sand Blasted Valve Pan Cover...$40.00 Shipped
-Supra Turbo 440cc Injectors..Black Top..Was Sent to Get Cleaned&Flow Tested...etc...$115.00 Shipped
-Supra N/A 300cc Injectors...Yelllow Top...(6)...$70.00 Shipped
-B16A JDM 61mm Throttle Body...Has TPS....No Map on Throttle Body or Fast Idle Fast...$50.00
-91 Integra Coupe OEM Front Lip...Good Shape....$35.00
-92-95 Civic Windshield Wiper Motor Unit...$50.00 Shipped Each I have (3) Of These
-91 Integra Front Cross Member with Bars/Bushings....$35.00
-92-95 Civic 4 Door Rear Window....$50.00
-92-95 Civic Hatch Rear Hatch Window/Hangers...$60.00
-D15B7 OBD1 Distributor...$45.00
-94 Integra LS 14" ACURA Hubcaps....Mint But 2 is painted gloss Black...Didnt get around to painting others..$35.00
-94 Integra Map Light $15.00 Shipped
-94 Integra Gauge Cluster Bazel $15.00 Shipped
-93 Civic EX Power Steering Rack 154k Miles...Has Tie Rods And Most P/S Lines Still on it...$50.00
-91 CRX HF Front Sway Bar...$30.00
-94 Integra LS REAR Sway Bar....$60.00
-91 Integra LS Coupe Tail Lights...RED AND Smoked...Stock...One Has lil Crack $30.00
-91 Integra Power Steering Pump $15.00
-91 Integra A/C Compressor $35.00
-88-91 obd0 B16A Rear T bracket...$50.00
-D16Z6 5 SPEED REAR TRANNY T BRACKET...$25.00
-AEM Black Silcone COupler...$12.00 Shipped
-B18C OEM OIL Squirters...With Bolts....$25.00 Shipped
-88-91 CIVIC D-SERIES Rear Tranny bracket..$22.50 Shipped
-(4)92-95 Civic Under Hood Fusebox...With Covers...And Have mostly all Fuses...$35.00 Shipped Each
(2)96-00 Civic Under Hood Fuse Box.....$40.00 Shipped Each
(5)92-95 Civic Under Dash Fuse Box's.All Relays...$35.00 Shipped Each
(2)96-00 Civic Under Dash Fuse Box....All Relays..$40.00 Shipped Each
-B18C JDM OIL Cooler Set Up...Complete...Thromostate Tube/Housing/Most Hose's/Oil Filter Sandwich/P72 Hose Extender Piece that goes under a Gsr manifold....$95.00 Shipped
-92-95 Civic Head Light Glass...Both Sides....$25.00 Shipped Each
-B18A1 LS STOCK PISTONS AND RODS...(8).....I Will Sell All them for ...$75.00 Shipped
-92-00 Civic/Integra Main Relays...Grey&Orange Ones....$25.00 Shipped Each
-96 Civic Tan under dash cover....$15.00 Shipped
THESE ARE ALLL UNDER DASH COVERS BELOW
92-95 Civic Black coverl...$22.00 Shipped
-94 Integra Black Cover $22.00 Shipped
-93 Delsol Black Cover,,,$22.00 sHIPPED
-91 INTEGRA 5 Speed Pedal Assembley,,,,$70.00 Shipped
91 Integra Steering COLUM...No wheel...$50.00
-92-95 Civic Steering Colum/w Key/Grey wheel....$125.00
-92 civic dash cover $15.00
-92-95 Civic RADIATOR SUPPORT....Great Condition...Includes Front Metal Bumper Support ,Hood Latch...$145.00 FIRM
-Old School PRELUDE/Accord Shift ****....$15.00 Shipped
-Alot of Different Sensors...etc...Lmk if u need anything
-Prelude passenger side tailight....$10.00
-94 Integra Over flow can $10.00
-94 Integra Complete Sunroof Assembley...has glass&Slider Etc&aLSO Will include Sunrood switch for interior...$85.00 Picked up
-Advanced air flow tech 5" Filter with Volcity Stack...I got a coupler that goes right on Aluminum and will Slip on a 3" IntaKE Tube or turbo...This was like $230 new with a ICE Man box....but dont have box...$65.00 Shippped ...Filter is More used now
-New Knock Sensor...Never ran just been in my garage setting $50.00 Shipped
-91 Integra 5 sPEED Gauge Cluster $60.00 Shipped
-96-98 Civic OEM Front Grill....Black Needs Cleaned up...$25.00 Shipped
-91 Integra A/C COMPRESSOR...$35.00+SHIPPING
-92-95 Civic Complete Interior Harness...Under Dash....$160.00 Shipped
-92-95 Civic Coupe Mint Rear Tail Lights....$55.00 Shipped
-94 Integra LS Rear Sway Bars/With End Links....$65.00
-88-91 D-SERIES Driver Side Motor Mount/Bracket...$35.00 Shipped
-92-95 Civic OEM UPPER Control arms...front....$50.00 Shipped Both
-92-95 Civic Driver Side Head Light...No Broken Tabbs....$55.00 Shipped
-92-95 Civic Front Bumper Support $30.00
-92-95 Civic Mint Radiator Support...$110.00
-92 Civic DX Grey Dash...Great Shape...Has glove box...Climate Control....$100.00
-91 Integra Power Mirrors...$22.00 Shipped Each
-92 civic 13/16 Brake Booster/Master...$50.00 Shipped
-92-95 Civic Front Lower Control Arms..With Black Polyurthane Inserts...$85.00 sHIPPED For both
-D16Y8 ALUMINUM UN Tappe Oil Pan...$90.00 Shipped
-95 Civic ABS ECU UNIT FOR TRUNK $50.00 SHIPPED
-92 Civic Complete Climate Controls...Under dash boxs...Such as Heater core/Blower motor/Spacer...$125.00 sHIPPED
-B18B1 HYDRO TRANNY FINAL DRIVE/RING GEAR...$45.00 Shipped
-94 Integra Door and Quater Moldings....$60.00
-92 Civic Windshield Moldings....$25.00
-95 Civic 4 Door Rear taillight harness $25.00 Shipped
-93 Civic Coupe Taillight Harness $25.00 Shipped
-92 Civic 5 sPEED Brake&Gas Pedal $55.00 Shipped
Phone #724-984-2168
PAYPAL READY
ASKING $335.00
INCLUDES
Valve Pan Cover
Vtec Solenoid
includes
Top Valve Train
Valve Pan Cover
Last edited by SlaminSohCivic; Aug 24, 2012 at 06:03 PM. Reason: addding more stuff
