Drag Lug nuts
Old Jun 2, 2012 | 12:31 PM
SPOOLINmatt's Avatar
Default Drag Lug nuts
What are you guys using for lug nuts? Ive had some steel ext lug nuts for a while and they are getting beat up. I cant remember what they are.
I looked at these
http://www.evasivemotorsports.com/mm...tegory_Code=L1
I have exospeed star8's...i know they work with the shanked with washer type lug nuts ....where can i get those......whats the better conical type to use. not really a fan of the aluminum lug nuts.
Old Jun 2, 2012 | 12:34 PM
jdm inc's Avatar
Default Re: Drag Lug nuts
I use the shanked type ones for my welds.
got mine from summit racing.
http://www.summitracing.com/parts/WLD-601-1452/
Old Jun 2, 2012 | 12:52 PM
92redhatch's Avatar
Got mine from velocityshop.com I think they're blox
Old Jun 2, 2012 | 01:10 PM
sanman000719's Avatar
blox
Old Jun 2, 2012 | 02:27 PM
porkythegrunt's Avatar
blox cheapo aluminum ones here
Old Jun 2, 2012 | 02:29 PM
yup mine have been on my car from the jump
Old Jun 2, 2012 | 05:39 PM
Zer0_SpeedWorks's Avatar
Using muteki open short steel lugnuts.
Old Jun 2, 2012 | 05:58 PM
nonvtecallmotor's Avatar
STOCK HONDA
Old Jun 3, 2012 | 07:43 AM
does the specified shank length include or exclude washer thickness?
Old Jun 3, 2012 | 08:39 AM
JayWest's Avatar
absolutely hated using those blox/aluminum lug nuts. they strip way too easily if you have to remove the wheels often
i use the shank style on my bogarts
friend ordered his from IPG and they sent the right size since we had no idea which one to order
Old Jun 4, 2012 | 12:42 PM
Mo_Spec's Avatar
We are using summit racing shank style with exospeed star 8's.
Old Jun 4, 2012 | 12:52 PM
the kicker is what shank length and diameter.
Old Jun 4, 2012 | 12:58 PM
Innes's Avatar
i stock the weld ones
Old Jun 4, 2012 | 01:16 PM
so you knows what i needs?
Old Jun 4, 2012 | 02:03 PM
JayWest's Avatar
yes they know which size, just give them a call
Old Jun 4, 2012 | 03:58 PM
fourthchirpin's Avatar
i hate the alum ones as well they strip soo darn easy. Anybody know where there are actual steel ones, none of that fancy business.
Old Jun 4, 2012 | 04:23 PM
zakura R's Avatar
Blox with no problem in here for 2 year
Old Jun 5, 2012 | 01:46 PM
ATYPR's Avatar
Originally Posted by nonvtecallmotor
STOCK HONDA
can only be used with stock honda ball seat wheels
Old Jun 5, 2012 | 01:51 PM
Or any wheel with a 60% seat.....
Old Jun 6, 2012 | 02:30 AM
rudebwoy's Avatar
blox extended cromoly open ends, I used aluminum lug nuts before and and after some passes and burnouts on slicks, I had to use a dremel to remove 2 of them, they got so hot they just twist when I tried to remove them.
Old Jun 6, 2012 | 02:52 PM
IN VTEC's Avatar
I went with these to retain using a typical 19mm or 3/4" 6pt socket to remove the lug nuts without a tool that could be hard to find if we were away from home.
They're steel and don't have problems galling. Smack them with an impact all day if you want.
https://www.pegasusautoracing.com/pr...asp?RecID=5686
Old Jun 20, 2012 | 06:36 PM
Alright got some weld nuts.
Does anyone here torque their wheels to a specific torque?
Old Jun 20, 2012 | 06:45 PM
90sedan's Avatar
I always torque mine to 80ftlb
Old Jun 27, 2012 | 08:54 PM
h22-eg-hatch's Avatar
X2
I have had my chromoly lugs for a couple a yrs.
Been taken Off 20-30 times easy... Still near Perfect
Old Jun 28, 2012 | 01:55 AM
kantspell's Avatar
what about evo lugs on bogarts? for a honda the thread pitch is the same but the hole in the bogart would need to be drilled out about .045. any thoughts?
