PA FS: 2000 Honda Civic Si EM1 EBP
Hello ht
2000 Honda Civic EM1
136,xxx on body
12,xxx On motor
Engine
B20b Block
B16 Head
B16 Trans
Mugen Axle Back
Has Cat
ITR Pistons
The motor was built by Ramey Built in VA Beach. Which if any of you know it is a greatly respected shop on the east coast. I have all the recipts. It runs great and i have had no problems with it.
Interior is Stock
Wheels/ suspension
The car will come one drag dr20s
GC Coilovers and yellow shocks
Bad:
Steering wheel is a little worn
Needs A driver swaybar endlink
Missing front lip and bumper needs mounted correctly and the foglights fit poorly.
Ive had this car for about 2 months and because of recent events i want to get my type r project off the ground. The car is in good shape it just needs someone who knows what there doing to fix the minor issues it has like i was going to i just dont have the time.
Price 5900
If you dont like my price keep your comments to yourself.
136,xxx on body
12,xxx On motor
Engine
B20b Block
B16 Head
B16 Trans
Mugen Axle Back
Has Cat
ITR Pistons
Interior is Stock
Wheels/ suspension
Bad:
Price 5900
No power steering but i have all the parts
No cruise but have the parts as well
Yes it has a clean title
And the head and Trans are stock to the car and as far as the block the previous owner never gave it to me.
B20b block
Honed
Itr spec pistons
New oem rings
Arp rod bolts
B20 crank
Stock rods
New timing belt
New water pump
Dc 4-1 header
New headgasket
B16 head
Resurfaced
New valves
Stock cams
Bdl cam seal
Comp stage 2 clutch
P28 ecu on Chrome
Car made 189hp 147ftlbs
The car would make a lot more with a nice set of cams and a nicer exhaust setup which I was going to do but I have to much going on to get to it.
I also have the recipts from ramey built but don't have a scanner.
Honed
Itr spec pistons
New oem rings
Arp rod bolts
B20 crank
Stock rods
New timing belt
New water pump
Dc 4-1 header
New headgasket
B16 head
Resurfaced
New valves
Stock cams
Bdl cam seal
Comp stage 2 clutch
P28 ecu on Chrome
cyclotegra
Jul 21, 2013 05:02 PM
