slow 06 si
So i have an 06 si with Aem short ram, Dcrh, and tsudo catback as for now and i feel that the car is still not that fast
, and laggy a little. what other parts should i get that will increase the cars performance for cheaper im really low on money but yea, besides flashpro
And you bought a civic were you really expecting it to be "fast" with just i/h/e?
EG's weight ~ 2200
FG2 weight ~ 2875
Of course the FG2 will be more sluggish; it weighs a lot more with similar power levels (
). As was said, get Flashpro and a tune to make the most of your current mods. There really is no point in buying bolt ons for these cars without getting a tune; they may even hurt performance without a tune (especially the intake). You don't want to be running lean (which many intakes have been seen to do) for too long.
Also, you might want to ditch the SRI for a CAI; the SRI draws air from one of the worst places possible. Or, you could relocate your battery and flip your SRI to draw air from behind the headlight - not as good as a CAI, but a lot better than where it's currently at.
FG2 weight ~ 2875
). As was said, get Flashpro and a tune to make the most of your current mods. There really is no point in buying bolt ons for these cars without getting a tune; they may even hurt performance without a tune (especially the intake). You don't want to be running lean (which many intakes have been seen to do) for too long.Also, you might want to ditch the SRI for a CAI; the SRI draws air from one of the worst places possible. Or, you could relocate your battery and flip your SRI to draw air from behind the headlight - not as good as a CAI, but a lot better than where it's currently at.
very true even with a calibration from flashpro I was still running lean in the 2500 to 3500 rpm range with i/h/e, rrc manifold, & j35 tb. Found this out after my tuner started to mess with my car on the dyno
Ditch that short ram for a cai. Try the 3.5" custom. Also flashpro!!! and do not do a dyno tune! I mean if you want to spend the money go for it but if not try e-tunez. Best bang for the buck! Also try arizona8thgen. You are close to Az so you could join up and they are full of information.
yea i can tell, the bubble was so light and forgot to mention it was gutted inside but yea i cant wait to get the flashpro and i know i need to do something about the intake i had a CAI before but switched to SRI because it kept getting wet and dirty:\ but i heard u could put a heat shield there, and about the flashpro tune, will it be ok if i just run one of their map tune that the flashpro comes with??
The pre-programmed tunes are hit or miss. They seem ok to some people, but not for everyone. Not all cars react the same way to mods or tunes. I'd recommend getting the ultimate tune from e-tunez.com; probably one of the most cost effective and quality tunes you'll ever get.
If you wanna save a bit of money for now you can go to Flashprotuning.com they have more developed base maps that are directly from previous cars they have tuned. If you want the most out of the car hit up Vitviper at E-tunez, he dose amazing work!
Keep in mind, I was still running lean with one of the basemaps from Flashprotuning.
And yep, VitViper is definitely one of the best out there. I have my e-tune from him as well.
When you turn the ignition to ON, the FlashPro Manager will recognize that it's plugged in and you can tune or flash your ECU with a map from your laptop.
Look up the tutorials here: http://www.hondata.com/flashpro.html.
don't know anymore, i like the Si a lot but power sucks without putting tons of money into the engine..btw i didn't get the flashpro yet i'm still looking for one but i feel like even with flashpro the car will still be slow and ill need to spend 3-6k for a supercharger or turbo, like i wonder if i would be able to keep up with a stock WRX or STI with i/h/e/fp..and i don't think it will, so i'm thinking about getting a golf IV r32 but still confused:\ because id like to turbo the Si but no money, i can only trade the car.. or i wonder if i could find a cheap turbo kit i could throw on it, not ebay.. help me guys with ur opinions
JohnQPublic
Honda Civic (2006 - 2015)
35
Aug 28, 2009 01:47 AM
