Need advice on Koni/GC install (99 Accord coupe)
Old Jun 1, 2012 | 05:20 PM
1991EX's Avatar
Default Need advice on Koni/GC install (99 Accord coupe)
I just recieved my koni/ground control set up, and I also ordered new shock mount rubber along with the new rubber for the inside of the factory top hats. I need to know if I use the new top hat rubber with this set up. The GC's came with a rubber upper spring perch piece, but it is not the same diameter as the factory top hat. It appears to be more of a bushing.
If anyone has installed the Koni/GC set up on a 98-02 accord using the original top hats, can you please advise?
Thanks!
Old Jun 2, 2012 | 11:39 AM
1991EX's Avatar
Default Re: Need advice on Koni/GC install (99 Accord coupe)
I moved my post to the suspension section hoping to find help there, thanks.
1991EX
Suspension & Brakes
Jul 16, 2012 07:36 AM
DialedLife
Jul 11, 2012 10:45 AM
1991EX
Suspension & Brakes
Jun 12, 2012 06:48 AM
