Transmission & Drivetrain Gearboxes, Differentials, Clutches
LX vs EX automatic trans different?
Old Jun 1, 2012 | 09:25 AM
Boosted.Ctr's Avatar
Default LX vs EX automatic trans different?
I have a 1996 Civic LX that is an auto trans, the trans slips every time it shifts gears? I have an extra 1999 Civic EX auto trans sitting in my garage, I want to know if there's is a different from the LX and EX trans or if I can swap it out? Thanks
Old Jun 1, 2012 | 11:16 AM
94EG8's Avatar
Seagull Management
Default Re: LX vs EX automatic trans different?
They're different. 3rd gear ratio IIRC is the difference. It will throw a code P0715.
Old Jun 3, 2012 | 12:36 PM
What if I used the EX transmission computer, would I still get the code? Or would the Ecu throw the code? Thanks
Old Jun 3, 2012 | 04:00 PM
94EG8's Avatar
Seagull Management
The car uses a PCM, engine and trans computer are all one. If you use an EX ECU it will throw codes for the vtec solenoid and pressure switch.
Old Jun 8, 2012 | 07:57 PM
Sounds good, Thanks guys...
Old Aug 2, 2012 | 08:54 AM
Nitrous1024's Avatar
The LX has the better fuel economy to begin with since it has the longer gear ratios. The EX will feel more sporty with the shorter gear ratios as the expense of fuel economy. As previously mentioned, you will get error codes for the VTEC solenoid however.
Old Aug 3, 2012 | 05:44 PM
94EG8's Avatar
Seagull Management
Not true, at least for the '92 - '95 Civics. I never bothered to look into the automatic ratios for '96 - '00, but the '92 - '95 automatic civics actually have a longer geared transmission in the EX models for better fuel mileage because the engine made enough power to haul itself along at a lower cruising RPM. The manual version is exactly the opposite.
Old Aug 4, 2012 | 04:02 AM
Thanks for the clarification.
Chriser0
10
Aug 17, 2013 02:58 PM
shawnlee250
Honda Civic (2001 - 2005)
May 19, 2012 09:54 PM
ucd_4_life
Mar 25, 2012 05:55 PM
BOMBCRU
11
Aug 25, 2011 01:57 AM
hmt_eg
Feb 15, 2008 06:48 PM
