K series to Chevy trans adaptor
Old May 31, 2012 | 05:42 PM
nos51's Avatar
Default K series to Chevy trans adaptor
as title says want to know if anyone out there has made one yet or if its avalable.any help would be apreciated. Btw I need a Powerglide/th400 bolt pattern
Old May 31, 2012 | 05:56 PM
MARC P's Avatar
Default Re: K series to Chevy trans adaptor
Contact Innes.
Old May 31, 2012 | 06:17 PM
SwappedTURBOegg's Avatar
i want one thats reasonably priced too oo
Old May 31, 2012 | 06:40 PM
redboost10's Avatar
Everyone wanted around 350-400 for a 1/2" one. We ended up making a few out of 1/4". No need for 1/2"
Old May 31, 2012 | 06:52 PM
nos51's Avatar
$350-400 you mean?thats not bad. You have any avalable still?also what you do about the flexplate?
Old May 31, 2012 | 07:01 PM
West Werks's Avatar
I have a cnc'd blank plate (flywheel ring and starter provision cut out) for a K-Series to a SBC/BBC. New, never used, not even mocked up.
Old May 31, 2012 | 07:03 PM
Brent L's Avatar
I have a plate done and just sitting
redboost10's Avatar
Rob Youngblood (advanced clutches) does all our clutch/torque converter stuff. I think we may have some 1/4" blank plates.
Old May 31, 2012 | 07:05 PM
civicguy's Avatar
saw one with atached tabs on the flywheel to grab the converter,ill try find a pic
Old May 31, 2012 | 07:48 PM
eg_bseries's Avatar
http://www.ipgparts.net/
They have a whole setup for sale.
Old May 31, 2012 | 08:36 PM
RaceLAB's Avatar
Josue, we got a 1" thick aluminum plate with only K series Bolt holes cut out in it that we originally were going to use on my 240 before we scrapped it for the MR2. Making the rest of the holes would be easy. If it interests you let me know. We got it sitting here at the shop.
Old Jun 1, 2012 | 04:41 AM
rickoner's Avatar
It's funny this thread popped up. I've been trying to research this same exact setup for the last 2 days. A lot of people seem to be making the plates but you never see them together and there's very limited info on the flexplate/converter setups along with the starter. Also it appears that the plates I've seen have the engine mounted straight vertically. Would that effect the oiling system at all since in sits at an angle stock?
Hopefully some more info or even a company will have a complete bolt together kit soon. I'm dying to build a small rwd car that can handle some power reliably.
Old Jun 1, 2012 | 05:32 AM
YZFR6's Avatar
Get a blank from SKR, RJ or Bickel everyone has one...
Old Jun 1, 2012 | 06:00 AM
Innes's Avatar
the setup we have here is for a FWD GM 4T65e transmission
i think they are looking for a RWD TH400 type setup
Old Jun 1, 2012 | 07:36 AM
mazracing's Avatar
http://www.mazworx.com/product/drive...to-gm-midplate
Old Jun 1, 2012 | 08:02 AM
nos51's Avatar
ok seems like the plates are out there mostly,who can make me a flexplate?
Old Jun 1, 2012 | 08:24 AM
efi2nr's Avatar
From: Home of the fastest Hondas in the 417 area since, 1997, usa
and who can make a converter that will allow you to leave over 5000rpm on only boost?
Old Jun 1, 2012 | 08:37 AM
nos51's Avatar
we run ptc converters that are built specifically to each setup based on weight engine set etc. it shouldn't be a problem.im not concerned about leaving only on boost because it will be on nitrous for spool up if needed
Old Jun 1, 2012 | 09:01 AM
Abraham-ATS's Avatar
i got two MID plates done here and one adapter plate in case u planning on using trans mounts instead of mountin a mid plate to the chassis bars... pm me if u interested. btw they are 1/2inch mid plates and 1inch adapter plate txt me 862-596-4279 if u want pics
Old Jun 1, 2012 | 10:33 AM
HickamHatch's Avatar
http://www.k20a.org/forum/showthread.php?t=95715
Originally Posted by bill hincher
Old Jun 1, 2012 | 10:41 AM
Martian's Avatar
^very nice piece
Old Jun 1, 2012 | 10:44 AM
redboost10's Avatar
That's what we ended up with as well. Mr. Youngblood helped us out a lot with the rail car.
Old Jun 1, 2012 | 01:03 PM
nos51's Avatar
very nice!is that one off or is there more avalable?
Old Jun 1, 2012 | 01:44 PM
torres3030's Avatar
http://www.billsautofab.com/forums/f...ct=261#xx261xx I think Bill is the best. Go to his hompage and call him. Very humble guy. Right now his doing a complete bellhousing for my friend, for a 4g63 to a liberty clutchless transmision. If you think of anything to adapt any transmission you have, to what ever motor you have call this guy.
Old Jun 1, 2012 | 02:15 PM
nos51's Avatar
this is exaclty what im looking for thanks!only issue i see is the starter since the adaptor pulls out the flywheel away from it.maybe he has it figured out by now
