Duralast vs HF vs. Craftsman Torque Wrench?
Old May 31, 2012 | 05:00 PM
sxysweed's Avatar
Default Duralast vs HF vs. Craftsman Torque Wrench?
I'm looking for a decent-to-good torque wrench. Can't afford Snap-On/Matco/Etc, it's completely out of the question. I'm stuck between buying a beam-style Craftsman wrench because I know they're pretty accurate, but they're difficult to read. I've heard good things about Duralast ratchets (copies of Snap-On's) so I considered a Duralast Click-style Torque Wrench. And there's also Harbor Freight, but with the build quality on the ratchets they have (pretty notchy) I'm not sure if I could trust a HF Torque Wrench. What would you do?
Duralast:
http://www.autozone.com/autozone/acc...er=914018_0_0_
Harbor Freight:
http://www.harborfreight.com/1-2-hal...rench-239.html
Sears/Craftsman:
http://www.sears.com/craftsman-150-f...7&blockType=G7
Old May 31, 2012 | 10:13 PM
doood's Avatar
been there done that
Default Re: Duralast vs HF vs. Craftsman Torque Wrench?
not everybody can afford a $500 torque wrench
my craftsman 3/8 is fine for 99% of everything i do in my driveway. matter of fact, the only thing i've used it for in the year or so i've had it is a clutch/transmission job and lugnuts. everything else i go by feel. nothing's come loose yet.
Old Jun 1, 2012 | 07:09 AM
HeikDiesel's Avatar
Originally Posted by solbrothers
I've seen first-hand that anything but the digital torque wrenches are a gamble
This is absurd. Twist type torque wrenches need to be dialed down after every use. Dial type do NOT have to be, but I do anyway. Most are rated +-3% or better putting you within the standard torque range for most fastners. Digital is garbage and a waste of money and only truly useful in very few applications
Old Jun 1, 2012 | 07:20 AM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
What do you mean by being dialed down?? First I have heard of this.
Old Jun 1, 2012 | 07:36 AM
sxysweed's Avatar
If you set it to 80ft/lbs to torque lug nuts, you have to set it back to "0" when your done.
$250 snap on is wayyyyy out of my range.
Old Jun 4, 2012 | 02:16 PM
mechanix619's Avatar
Duralast:
Harbor Freight:
Sears/Craftsman:
I would never ever trust a HF tool for something as important as torque specs.
My best advice is to save until you can afford a quality tool otherwise you'll be purchasing two in the end.
I purchased a Snap-On split beam from eBay and had it calibrated. I only spent $100.
Old Jun 4, 2012 | 08:23 PM
90civicstdgold's Avatar
If your looking for a good torque wrench lmk
I have a few for sale.
Old Jun 5, 2012 | 12:14 AM
Vagitarian's Avatar
Sears craftsman TQ wrenches are on sale
And work great
Old Jun 5, 2012 | 10:19 PM
HeikDiesel's Avatar
also let's hear about how digital is garbage, a waste of money, and only truly useful in very few applications.
Digital ones usually do have a much better tolerance right out of the box, but with + or - values for every torque spec, you will never really deviate from that spec.
Also, digital ones use a vibrate function as well as a light, which can come in handy when working in adverse conditions when you can't really feel a torque "click". I used to use a digital when doing rod nuts on compressor stations where other engines were running with a lot of noise and vibration were I was unsure with a standard torque wrenches.
The twist type use a spring where if you do not return them to a "0" value, it may cause the spring to wear prematurely, were as dials use a totally different technique.
Old Jun 8, 2012 | 06:28 AM
BizzSol's Avatar
find a snap on truck rolling around and they sell remanufactured ones for way cheaper than retail, and every truck can test torque wrenches for you also
Old Jun 8, 2012 | 08:33 AM
turbohatch96y7's Avatar
Good to know I diddnt know they can test them
Old Jun 10, 2012 | 11:48 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Snap On does not manufacture their own torque wrenches. If you are looking for a quality torque wrench at a "some what "cheaper price you can try http://www.torqwrench.com/home.php
That is who they used in the past and currently the are using
http://www.cditorque.com/
Actually they bought this company a few years ago, So Im not sure if you can order from them.
Finally, I have seen this company come up a few times in the past. I have no personal experience with them , nor do I know anybody that does. But still, their product seems promising, and is very cheap.
http://www.brownlinemetalworks.com/index.php
A digital torque wrench is best. It is more accurate than any mechanical torque wrench and will better retain this accuracy. All though a quality mechanical torque wrench will work just as well (and is much cheaper). Now, for some people "good enough" is the way they do things and that is how they justify using a cheap, low buck torque wrench. If you are one of those people, where precision is not important to you, then just buy whatever wrench is cheapest. There really is no difference on the low end of the spectrum....
(BTW I have two Snappy Techangles, a Snappy split beam for tires and a Snappy click type that reads in inch lbs.)
wc4ohio
Apr 24, 2011 04:52 AM
thawley
66
Dec 29, 2005 03:40 PM
slowride2
Feb 4, 2004 05:59 PM
int3gra
Sep 3, 2003 11:21 AM
