H22A Type SH
Old May 31, 2012 | 12:57 PM
LM1092's Avatar
Default H22A Type SH
Do you need the Active Torque Transfer System (ATTS) when doing a swap in a 6th gen Accord
Old Jun 1, 2012 | 04:34 AM
v4lu3s's Avatar
RTFM
Default Re: H22A Type SH
if you have to ask....its way over your head. to have atts work will require a lot of wiring and adding stuff for it to work.
you are better off using a non atts h22 swap.
Old Jun 1, 2012 | 05:19 AM
GhostAccord's Avatar
It's only the trans that is ATTS isn't it? Or are there differences in the block as well?
Should be able to use the SH H22A4 engine, just drop the ATTS trans and pick up a regular H22/H23/F22/F23 trans. Anyone of those will bolt up nicely with no added headache.
Old Jun 1, 2012 | 07:40 AM
LM1092's Avatar
Well the Intake I want to use isn't compatible with the ATTS due to clearance issues and the Type SH H22a has a higher Compression ratio and more Torque than the base H22a
Old Jun 1, 2012 | 08:23 AM
What engine code is stamped on the block & head? H22A4 & PCF or something else? I always just assumed it was only the trans that was different.
Old Jun 1, 2012 | 09:06 AM
thundernoodle's Avatar
quoted for truth.
ATTS blocks are different than regular blocks in a couple small but key ways. Simply put find a base engine and forget ATTS.
Old Jun 1, 2012 | 09:08 AM
Not. The Type-S engines have a slight bump over regular H22's but here in 'Merica the H22A4s are all the same internally
Old Jun 1, 2012 | 10:04 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
You can bolt the base model trans to an SH block. However, you'll need to fabricate a plate to mount the intermediate shaft. If not, you can use the ATTS unit as an intermediate shaft and leave the unit unplugged. Just keep fluid in it. Loop the cooler lines or run an auxillary cooler.
Or just use a single cam axle on the driver's side with the base model trans? I haven't tried it...but it seems like it'd work. It would eliminate the need for the intermediate shaft.
Old Jun 1, 2012 | 12:45 PM
v4lu3s's Avatar
RTFM
or best bet yet get a non atts engine and make life easier, and not carry around the extra 50+ lbs of crap under the hood and not have any kind of weird issues with aftermarket performance parts.
Old Jun 1, 2012 | 01:32 PM
^ Im not 100% sure maybe Bserious knows, but you cant put an LSD in an SH case.
Old Jun 1, 2012 | 04:53 PM
B serious's Avatar
^probably not. The whole thing is really complicated. I don't think a mechanical LSD would work at all with ATTS.
I'd rather have a normal trans with a mechanical LSD.
Old Jun 2, 2012 | 09:54 AM
Hidenplanvew's Avatar
Non Atts ftw...
Old Jun 3, 2012 | 02:55 PM
v4lu3s's Avatar
RTFM
not possible to put an lsd into the sh case with stock parts, it MIGHT work with some custom bearings and custom seals though.
preludepower89
Mar 16, 2007 01:40 PM
sluger17
Mar 21, 2006 11:37 AM
Jynxeh
Feb 9, 2006 10:29 AM
0ptimus prime
Apr 25, 2003 07:19 AM
0ptimus prime
Apr 10, 2003 10:29 PM
