B-Series Swap Parts / K-Series Clutch / 450cc DSM / Cams / EM1 Side markers
B-Series Axles The Pair $40
Integra EG / DC Rear Bracket $40
B series Alternator OBD1 $50
B Series Sarter $50
B Series Flywheel $40
B series B16 Cams $60
B series DOHC Valve Cover $70
EK / EM1 Side Markers 98-2001 Civic $30
Brake line tuck Kit // Comes with 25ft roll of steel brake line and fittings/bulk heads,$100
DSM 450 Injectors $80 Great for Turbo Hondas
3" T bolt Clamps (10) $35
ARP GSR / LS VTEC Head Bolts $50 - Missing only 2 nuts, can order 2 for dirt cheap
Golden Eagle LS-VTEC Dowel pins (new) $20
B series Integra / Civic EG DC EJ Motor Mounts (2) Transmission and driver side $100
Honda and Acura Shifters $10 Each
T3 / T4 / GT35R / GT40 / G30R Turbo oil line $45
PR4 ECU OBD0$40
P06 OBD1 ECU $60
B series Spark Plug Cover $10
SOHC Valve Cover $20
(Blue) NGK B-Series Spark Plug Wires $50
(RED) Aftermarket B-Series Spark plug wires $30
Various Post mount Brackets $20
B-series Aftermarket Fuel Pressure Regulator $30
B-Series Fuel Rail $25
Emissions Canister $30
B series Oil pan Baffle $10
B-Series head cam caps $10
B series cam rails $10
Civic Integra. D and B series Radiator Hoses $5
K Series Exedy Clutch and Presssure Plate $190
Eagle Rods B Series, B16, Like new $220
915-549-3724 Alex
B Series Sarter $50
PR4 ECU OBD0$40
P06 OBD1 ECU $60
915-549-3724 Alex
