BKR7e-11 plugs in GSR
Old May 30, 2012 | 04:41 PM
mr_munro's Avatar
Default BKR7e-11 plugs in GSR
NGK Plugs
Just wondering who is using these plugs in a stock Integra VTiR (GSR)? Are they safe?
There seems to be mixed things on forums in regards to using 6 or 7(colder) plug.
Would these also be safe to use in an AUDM spec DC2ITR (11:0 cr)? Is a '5' plug too hot for an ITR it would cause damage?
Thanks
Old May 30, 2012 | 05:15 PM
Turbo-LS's Avatar
Default Re: BKR7e-11 plugs in GSR
If this is not a turbo/nitros/supercharger application then you shouldnt be running a heat range of 7 on your plugs. Stock plugs are cheap why bother trying something else?
Old May 30, 2012 | 05:17 PM
mr_munro's Avatar
Just needed more info if 7 was too cold for a stock NA application. BKR7e-11 were promo plugs, i got them for nothing which is why i asked.
Old May 31, 2012 | 07:26 PM
mr_munro's Avatar
Can anyone answer my 2nd and 3rd question
Old May 31, 2012 | 08:01 PM
FlewByU352's Avatar
Best thing to do is test them. You will know if it runs too cold by looking at the plugs. In an ITR run the 7 heat range, for a GSR optimal would most likely be a 6 though.
1sikhatch
Feb 25, 2007 02:51 PM
combustion
Sep 4, 2002 06:29 PM
PTownGSR
Jun 5, 2002 05:14 AM
gsr98vtec
Apr 25, 2002 12:11 PM
Babalouie
Jun 24, 2001 07:33 PM
