Tilton clutch issue...
quick run down,Tilton cerametallic clutch with tilton throw out bearing setup with a control valve. When i go to push the clutch in it bogs the motor and sometimes shuts it off. Any idea what could be causing this? I've bleed the clutch multiple times and the same thing is happening.
Thanks,
Will
Thanks,
Will
Just curious if you ever got this issue resolved? Running into the same problem right now with the strongest leads being the Omnipower Quicklutch is overstroking it or the clutch is binding up or the diaphram isn't releasing enough.
LOGONZOJLS
Jan 29, 2007 02:40 PM
