Cam Shaft position sensor?
For a 2005 Pilot, I know there is a Crank Shaft position sensor. I am wondering if there are Cam Shaft position sensors for the ECM to monitor and co-ordinate the timing between the two Cam Shafts and Crank Shaft?
Hope this helps!
Thank you for the info, Wes Wagon! I just did the timing belt change. Pretty sure did everything right. Just try to gain some confidence as the CKP and CMP will tell if there is any teeth missed.
