AEM ECU 30-1010 Box Honda/Acura Engine Management System
Old May 29, 2012 | 07:51 PM
civicxpress's Avatar
Default AEM ECU 30-1010 Box Honda/Acura Engine Management System
This AEM was recently sent out and had the hall mod done so you can run a coil on plug setup instead of a distributor. Mod alone was $175 You can reach me at 413 218 3152,steve
I have two of these both have the hall mod done to them. Looking to get $500 each free shipping to anywhere in the USA
AEM Engine Management System Honda/Acura
Applications: Acura Integra 2000-2001, Acura 2.3CL 98-99, Honda Accord 98-02, Honda Civic 99-00
The AEM Engine Management System (EMS) is the result of extensive development on a wide variety of cars. Each system is engineered for the particular application. The AEM EMS differs from all others in several ways. The EMS is an all new stand alone system, which completely replaces the factory ECU and features unique Plug and Play Technology, which means that each system is configured especially for your make and model of car. There is no need to modify your factory wiring harness and in most cases your car may be returned to stock in a matter of minutes. The AEMPro software is configured to work with the factory sensors and equipment, so that there is no need for expensive or hard to find sensors, making replacement and repairs as simple as with an unmodified car. For stock and some slightly modified cars, the AEMPro software will be preprogrammed with a set of base parameters, providing a starting point for individual tuning. For more heavily modified cars, the EMS has many spare inputs and outputs allowing the elimination of separate rev-limiters, boost controllers, nitrous controllers, and fuel computers. It will also allow programmable control over all automatic transmission functions, and includes a configurable onboard data logger capable of recording 512kb of information. Every EMS comes with all functions installed and activated, and there are no expensive options or upgrades to be performed.
The installation of the AEM ECU on the 2000-2001 Acura Integra / 1998-1999 Acura 2.3CL / 1998-2002 Honda Accord / 1999-2000 Honda Civic uses the stock sensors and actuators. The base map is automatically installed in the base calibrations directory in the AEMPro directory on your computer. It is named 1010.V1.10.CAL
mrjenkins
Nov 2, 2008 04:24 AM
hondamike.com
Jul 26, 2007 04:44 AM
hondamike.com
May 19, 2007 02:33 PM
Boner_Ben
Oct 31, 2004 09:57 AM
