M&W,AEM,LS crank,Tons more!
3 GRP B-series aluminum rods standard LS length rod. 2 are mint other is slightly damaged from the engine letting go. Comes with 3 84MM (GSR)CP pistons with upgraded wrist pins. This combo had 30 passes on it when #4 rod spun a bearing. $200 for everything.
CP wrist pins #827-2250 new set of 4 $75
ARP Head Stud Kit - LS Vtec Conversion #208-4303 torqued once SOLD
Stock integra gas tank with sump welded in. Works great comes with everything pictured. $SOLD
GSR head, tons of work done to it. Bronze valve guides, Intake and exhaust valve openings are +1mm. Both intake and exhaust ports have a ton of port work done to them. Only thing it needs is a good cleaning. Comes with cam caps! Bare head $SOLD
Misc. parts $10 each.
OBD1 alt. works perfect $50
B-series starter works off and on $25
Integra center console $10
B-series OEM plug wires $10
Integra complete wind sheild wiper setup $20
B-series timing cover $10
Hasport mounts b-series. pass side is a auto to manual SOLD!
LS crank $50 would be good for a stock rebuild. needs to be polished few scratches
LS windage tray $10
LS cluster, used this for parts... might work...$20
Gates racing GSR timing belt used $20
Vibrant 4" coupler $20
Vibrant 4" Velocity stack, Stack was $80 alone new. $50 for what you see.
ALL prices are OBO. More pictures available by request.
LS windage tray $10
