removing paint from fat 5 GSR wheels
Old May 27, 2012 | 08:06 PM
theguy22's Avatar
Default removing paint from fat 5 GSR wheels
Ok, so i have some fat 5 GSR wheels that are painted black.. i want to remove the paint. i was going to try using aircraft paint remover. but now im wondering, if i remove the paint, will i need to apply clear coat to the wheels after I'm done? is it necessary? or am i good with just stripping the paint off and washing it. i want that factory look back. thanks
Old May 27, 2012 | 09:38 PM
jbpnoman's Avatar
Default Re: removing paint from fat 5 GSR wheels
You can strip them and polish them without needing to clearcoat, just be sure to keep them clean and polished, especially if you live in a rust-rich environment.
Old May 28, 2012 | 11:36 AM
theguy22's Avatar
would it look bad if i clear coated them?
Old May 28, 2012 | 02:03 PM
gzes's Avatar
No just more glossy
Old May 28, 2012 | 08:27 PM
chawski's Avatar
are they cleared in stock fashion? Aircraft remover is gonna take em down to the metal. even a rattlecan clear coat is better than nothing if you think you can do it
Old May 29, 2012 | 12:15 PM
TunerN00b's Avatar
They were machined and clear coated from the factory. If you want the stock look, you'll need to re-clear them.
If you want to polish them, then they'll need regular maintenance to keep the look. That isn't how they came, but polished looks better to most people than machined.
Old May 30, 2012 | 09:53 AM
theguy22's Avatar
but the main reason why i ask is because i don't want my rims to corrode. will polishing them help on corrode the rim? or does alloy just last forever like that haha
Old May 30, 2012 | 10:04 AM
TunerN00b's Avatar
Polishing removes any oxidation, but it will come back without a protective coating. Meaning, if you don't want to have to regularly fix them, you'll need either clear paint or a clear powder coat.
WhiteGSR95
Paint and Body
Apr 7, 2012 07:01 PM
jdmekrobot
Aug 5, 2007 09:24 AM
be18see1
Dec 13, 2006 08:52 AM
90AccordVTEC
Apr 21, 2006 08:33 PM
