Transmission & Drivetrain Gearboxes, Differentials, Clutches
what type of clutch for turbo
Old May 25, 2012 | 10:48 PM
jdm itr integra's Avatar
Icon7 what type of clutch for turbo
had my civic dyno it made 369 whp and 222tq took it to the track and on my 3rd pass my clutch started to make noise, its a act heavy duty 6 puck unsprung. just took it off and this is how it looks like, need hellppppp? what kind of clutch should i use to prevent this from happening
Old May 25, 2012 | 11:21 PM
Dc4LsTeG's Avatar
EK9
Default Re: what type of clutch for turbo
Ill be using a CC stg 4 on my build, shooting for more power then you.
Old May 28, 2012 | 09:49 PM
Mista Bone's Avatar
D Tranny Guru
Action
Old May 28, 2012 | 10:19 PM
eg6 type-R's Avatar
my CC stg 4 clutch had lots of problems with high rpm shift lock.. so have many other ppl.. i did my research after i noticed the problem and sure enough.. alot of ppl had the same issues to what i have..
then after 1645 miles, i pulled it off to replace it with exedy and found hotspots on my new CC flywheel, chips, and cracks on the clutch...
good luck with CC
they even replaced my whole kit and same issue occured..
my exedy is running alot better than CC
blkbb6
Dec 8, 2011 04:39 AM
vtec8804
Dec 10, 2006 01:39 PM
Stock@$$GSR
Dec 16, 2003 03:05 PM
zoku
Oct 7, 2002 07:16 PM
ALF
Nov 30, 2001 09:58 PM
