Honda Odyssey: Guess that Cable!
Hey Honda guys, now before we get anywhere further, I just want to say that I love you. I know that it's a bit fast in our developing relationship seeing how this is probably the first time we've meet but I feel a connection you know and I just have to say before I lose my gut.
Anyways straight to business. Me mums 2002 Honda Odyssey has a bit of a problem. A cable connecting to the engine, right next to the hoses is loose in a bad way. I have no idea what the hell it is (though it could be a throttle body cable) and I was hoping that you lovely people might know. here are some pics I snapped.
I circled it for easy viewing
Wide Shot
Wide Shot
I think you're right, it would explain the rough engine running at only operating temps. Thanks. Im going to take it to Honda soon.
The only way I see them being related is if the radiator fans failed to come on due to the busted switch and caused the engine to overheat which could have resulted in damage --> rough running. Who knows.
Of course, if there is a lack of coolant, or if there is air in the system it could be that the temp sender is not reading accurately - that would mess with the ECU --> rough running. Now that could all happen because of a missing hose clamp....
Thermo switch, for the radiator fans, but it runs through the ECU. Part number: 37760-P00-003
I'm not sure about that... there is a second temp sender located nearby which would provide temp data for the ECU and the gauge. This one just kicks as hot coolant hits it when the thermostat opens.
ruth.agius
Honda CR-V & Element
Oct 2, 2017 04:52 PM
EKtypeRhaTcH
Jul 6, 2003 06:46 PM
