FS: May-August RACE PARTS
MUST HAVE PICTURE
Only post for sale ad's of RACE PARTS
NO WTB
DO NOT REPLY TO A POST.....PM the person....Keep this thread free of banter....just FOR SALE Posts
MUST HAVE:
Contact
Location
Price
If you do not follow rules your post will disappear !
Chad
NO WTB
MUST HAVE:
Contact
Location
Price
Chad
For Sale:
Brand new set of std. size (81.00mm) Honda OEM Piston Rings.
I bought these along with some other engine parts from a dealership and since then I found out I will be going oversize on my pistons. The stealership I bought them from would not take them back after 10days from purchase.
So I am looking for $120shipped or best offer!
email: vtecintegra9 at hotmail dot com or send me a PM (slower response from me)
Other Items I have started listing for sale: More info and pictures upon request as I am in the process of taking all of my pictures, etc. Will take reasonable offers.
All parts from 1994 Integra GSR USDM
Tokiko Illuminas - Used not blown $200.00
Skunk2 Sleeves with 10k/8k Springs $110.00
Will sell together (current state) for 280+shipping
Used Neuspeed Race Springs $65.00
50% GSR Carbotechs $40.00
Power Steering Pump and Resevior $40.00
Lightweight Aluminum Crank Pulley & Belt $75.00
ABS Module $20.00
ABS Hydraulic Unit (94,95) $80.00
Integra Passenger Airbag $20.00
Cruise Control Stuff (removed) $25.00
Full Rear Interior $150.00
Carpet $20.00
A/C Compressor, evap, etc $20.00
Aftermarket Fog Lights New never installed $30.00
OEM Plug Wires $5.00
235/45/17 blizzaks 1 winter left (4) $120.00
Oil Pan w/ Hole in it $1.00
B18C1 Camshafts $100.00
GSR Rear LCA's with Poly bushings $40.00
Silver/Aluminum Dash dress-up Kit $20.00
GSR Valve Springs $50.00
GSR Valves $50.00
ABS Module $20.00
Carpet $20.00
GSR Valves $50.00
B series vtec Skunk2 Tuner Stage 2 Cams – $360.00, Next to new condition
B series Skunk2 Pro Cam Gears – $175.00, Condition BNIB
Sold - B16/B17 (208-4601) ARP Head Studs – $95.00, Condition BNIB
B16/B17/B18 (208-6401) 9mm ARP Pro Series Rod Bolts - $55.00, Condition BNIB
B Series, 8.8Lbs Toda Chrome-moly Flywheel - $260.00 Condition used very good surface
All parts plus shipping and open to offers! If you need more pictures let me know. Lots of other new, bearings, seals, gaskets and used B series engine parts, if you are looking for something let me know.
Thanks
Marc
sasso.marc@gmail.com
604-221-8775
Thanks
Marc
604-221-8775
Please text/email
770-337-9575 / justinsemon@yahoo.com
-Wicked Tuning Rear Toe Arms (spherical bearing) $190
-Wicked Tuning Rear Camber Arms (spherical bearing) $190
-Wicked Tuning Rear Lower Control Arms (spherical bearing) $230
-Wicked Tuning Front Upper Control Arm $140
-BC Racing Custom Valved Coilovers F:14k R:18k $900
-99-00 SI 26mm Front Sway Bar w/ control arms $150
-ASR OG Subframe Brace (og silver) $125
-Rear Disc Conversion COMPLETE $375
(ep3 10.2" rotors, Rsx-s calipers powdercoated black, steel braided lines, HP+ pads)
-Wilwood Dynalite 4 Piston Calipers, steel lines, DX Spindles, New Bearings, ARP Studs, 11.1" rotors and custom brackets, 11.8" 2 piece rotors and brackets (both clear most 15s), Hawk DTC60 pads (99% left) $600 ***PENDING***
-2001 OEM gsr 1" Master Cylinder / Booster $125
-15x8 +35 4x100 Kosei K1 Racing : Hankook RS3 225/45r15 (99.99% left) $900
-Fortune Auto Titanium Lug Nuts (16) ***SOLD***
-Kirk Racing 6pt Cage (optional "x" and door bars)
(powdercoated lime green w/ white pearl) (w/ mirror) ***SOLD***
-Custom Stainless Dimple Die Front/Rear Strut Bars ***SOLD***
-VIS Racing Carbon Hood w/ pins $300
-VIS Racing Carbon Lip ***SOLD***
-SiR (Vogue Silver Metallic) Grill $200
-RCrew Canards (powdercoated black) ***SOLD***
-APR Mirror Bases / TCS Carbon Mirrors (larger then apr) ***SOLD***
-OEM Sideskirts (bought new) ***SOLD***
-OEM Thin Side Moldings (bought new) $225
-OEM Roof Drip Moldings (bought new) $50
-OEM 99-00 Tailights $125
-EDM Valeo Headlights w/ Dark Grey Switch ***SOLD***
-Seeker V1 Wing (flawless bodywork and VSM paint)
(w/ carbon fiber CTR base) ***SOLD***
-Custom Alumilite Splitter (includes 2 blades)
(brackets bolt to factory tow hook location) $250
-Custom Rear Aluminum Undertray $150
-Password:JDM Fenders Rolled (vsm paint)
(w/ edm clear side markers) $225
-Sparco Rear Hatch Latches (new) $40
-ARC Switch Panel w/ Fuse/Relay Block $155
-Racepak IQ3 w/ Kpro Interface Cable ***PENDING***
-RCrew K Shifter Mount ***SOLD***
-Buddy Club Racing Spec Quick Shift w/ weighted ARC Style **** ***SOLD***
-Corbeau FX1 Bucket Seats w/ EK low rails (1 buddyclub, 1 memory fab) $675
-GForce 5 point Pro Series Harnesses (black) $300
-K20Z1 86.5mm 12.5:1 Wiseco Pistons, Circuit Hero chain guide, New OEM oil pump, Supertech Valvetrain, Skunk2 Stage3 Camshafts, TTS Oil Pan Baffle, S2 Exhaust Gear, Hybrid Racing Chain Tensioner $2750
-K20Z1 4.7fd Transmission w/ 08 SI LSD and new diff bearings $1400
-Ported/polished RBC Intake Maniold w/ thermal gasket
-74mm Hybrid Racing Throttlebody (w/ hr TPS and oem map) ***SOLD***
-Custom Aluminum 3.5" Intake w/ tbolts, coupler, and aluminum vstack $225
-Hybrid Racing Race Header w/ 3" vband $380
-Custom Coolant Overflow $175
-Custom Tucked Radiator/water neck/hard lines $450
-Custom Catch Can Setup (valve cover powdercoated wrinkle black) $300
-Hybrid Racing EKK1 Billot SOLID Mounts $400
-OEM Shift Cables w/ Solid Shifter Bushings $150
-Hybrid Racing Fuel Rail (black), black lines and fittings, black filter ***SOLD***
-RC 650cc Saturated Injectors $175
-Aermotive Fuel Pressure Regulator w/ Gauge (powdercoated wrinkle black) $150
-AEM Wideband Gauge Digital w/ sensor ***SOLD***
-AEM Oil Temp Gauge Digital (bnib) ***SOLD***
-Custom Aluminum Battery mount (behind pass side of front bumper) ***SOLD***
-Custom 3" Aluminum Exhaust w/ Aluminum Vibrant Race Muffler
(vband to header, wiggins on axle back) $600
-Competition Clutch Stage 4 Clutch w/ Race Flywheel $350
-DSS EKK1 Axles $225
98 Civic DX Shell: Clean title, fresh body work and vsm paint $1500
(paint cost more then that)
North of Atlanta
North of Atlanta
2000 Si Wheels
2 wheels have some curb rash, see photos
All are round and true [no bends]
R11 rubber on them, maybe one round of autox left on them [needs new rubber lol]
$300 obo
Northern California, Bay Area
PM Robin6
$300 obo
PM Robin6
$200 shipped Gsr 4.4 FD
- CS
- Ring Gear
$280 Shipped OMP Deep dish
- grey w/ white stitch
- fits all momo sparco hubs
$150 shipped B-series Hydro case halve Clutch housing
- legit with vin
- 2 avail
- price is ea.
$100 H22 Clutch & Flywheel
- used
- good life left
- CS
- Ring Gear
- legit with vin
- 2 avail
- price is ea.
- used
- good life left
Magnaflow Turn Down Race Exhaust (exits under shifter) - $130 OBO
2.25" piping.
PLEASE MESSAGE ME YOUR NUMBERS IF YOU'RE ARE INTERESTED. I am located in Irvine, but can ship at buyers expense.
2.25" piping.
For Sale:
Mugen DC2 driverside railset: $200
Recaro passengerside DC2 railset: $75
G Sport 6pt camlock harness: $75
G Sport 5pt camlock harness: $65
I have a few extra items from some project cars to get rid of. These are used but in well-cared for condition. All are genuine Recaro products from a Recaro dealer (Motovicity).
1) Recaro Steel Side Mounts (Type 2). One pair. $65 shipped.
These are advertised for the Pole Position but I used them on a Profi SPG. They should also fit the various SPA/Pro Racer/HANS models in the same lineup.
2) Recaro Seat Slider Tracks. Three pairs. $50 shipped/each.
These are the slider tracks you can use with VAC mounts and side mounts, like the Type 2 I'm selling. I am not including the original slider handles/levers, although these can be fabricated pretty easily or purchased brand new separately. All of the locking/sliding mechanisms work as brand new. For the first buyer I'll include some modified handles (for one seat) I used as a template.
Willing to cut prices for multiple items shipping together. PM me for contact info or any other questions. Thanks!
Pictures of exact items:
Putting my babes up for sale. Ive loved these since the minute i installed them. They are in amazing shape and look and ride like brand new. they have helper springs and the rears have GC tophats. they are 16-way adjustable and will accept edfc. Perfect Street/track coilovers. if you have any questions please shoot me a text.. 9374707339. i have plenty of vouches so feel free to ask about that too. serious inquires only please.
Spring rates:
F:14k
R10k
900 shipped.
Spring rates:
F:14k
R10k
900 shipped.
Bryan
Richmond Area
Pm or post here
$150
Selling a Race Fiberglass Tailgate for a 1992-1995 Civic Hatchback. This thing is stupid light, weighs maybe a few pounds and is about 35lbs lighter than the stock metal tailgate. Never even used it, just sat inside my closet so there's nothing wrong with it. Doesn't have the inner taillights or hole for license (hence the word race). Will come a rubber seal/weatherstripping off my old tailgate.
Can meet you at the East Coast Honda Meet if you plan on going if your from far away
Richmond Area
Pm or post here
$150
Someone ended up flaking, so I have 1 brand new set of PCI Aluminum Race Spec 5" Side Skirts for DC2. This includes all hardware for installation.
Asking $250 picked up in Irvine, CA.
FS: In Car Camera Mount
I have for sale an I/O Port style in car camera mount. Includes everything needed to mount to the cage and mount a camera. Asking $60.00 shipped USPS Priority. Located in GA.
You can contact me at Tibb7port@yahoo.com
For sale... two Eibach race springs (pictured).
freelength is 8"
spring diameter- 2.5"
spring rate - 200lb
$60 for the pair. Buyer picks up or pays for shipping.
Located in Glendale/Pasadena,CA.
freelength is 8"
spring rate - 200lb
