b17 Wiring questions just checking
Old May 24, 2012 | 09:20 AM
skaraider's Avatar
Default b17 Wiring questions just checking
Alright as you have seen on my previous post im doing hte 93 gsr b17 swap into my 94 civic.. and here is what i did.
I took the wireharness off the D series and the throttle body off of it as well did this for the Connector for the transmission speed sensor and for the Map sensor on the throttle body since the b17 has alot more vacuum operated stuff.. so my D series wire harness is plugged into the B17 motor.. all the connectors fit just had to extend the one for the connector that goes on the intake mani for the sensor under the fuel rail "unlike where on the D series its on the back of the mainfold" had to extend wires. so everything is connected.. so the questions is that should work righT>?
maxwellmercer
Apr 30, 2012 09:03 AM
beaterman
Dec 26, 2006 07:49 PM
Quad-Damag
May 19, 2004 11:05 AM
