B18B Swap Into EK Questions?
Old May 24, 2012 | 08:48 AM
chicows18's Avatar
Default B18B Swap Into EK Questions?
I got two questions.
1. On the driver side mount and braket, I use the two post bracket that bolts up to the block. THe problem is that I did that and now the bracket that connects that to the mount bolted on the chassis is way too high. I am wondering if I have the right two post bracket or if the other bracket is wrong? What combination could I possibly have and what exactly do I need?
2. I got on of the Integra AC line to bolt up. The one closest to the drive side chassis. The other one wont work. Is there an AC line that will work?
I am trying to finish this up today, so can anyone help.
Old May 24, 2012 | 08:27 PM
cruizinmax's Avatar
Default Re: B18B Swap Into EK Questions?
1. I used a civic si bracket that bolts to the block on the drivers side. Everything else was the original civic stuff. Can you post a pic?
2. If you use a crv a/c bracket you can use the stock civic compressor and lines.
shortstopNE
Apr 19, 2012 08:15 AM
lil danny
May 1, 2009 07:05 AM
geebs
Sep 24, 2008 05:46 PM
SyDuck
Jul 16, 2006 12:34 AM
hialeahzbg
Oct 17, 2005 02:08 AM
