dash removal?
Old Oct 13, 2002 | 07:46 PM
wannab20hatch's Avatar
Default dash removal?
Need help removin my dash with smallest amount of work. Pictures would help alot. In case ppl wonder why im removing my dash is becasue i need to remove my auto pedals and install my manual pedals. thanks in advance.
Old Oct 13, 2002 | 07:55 PM
crxforum's Avatar
Default Re: dash removal? (wannab20hatch)
This is for a CRX
Step 1:
Remove the rectangular plastic cover in the top center of the dash and unscrew the 12mm bolt hiding behind it.
Step 2:
Remove the side vent covers on the dash and the 12 mm bolts on each side.
Step 3:
Remove the instrument cluster cover. It has screws behind pop off panels on the top as well as screws that can only be seen by looking straight up from under the steering wheel
Step 4:
Remove the steering wheel.
Step 5:
Remove the turn signal/wiper switch.
Step 6:
From under the dash, remove the wiring harness for the instrument cluster from their plug at the firewall.
Step 7:
Remove a 10mm ground wire next to the cluster wires.
Step 8:
Remove the center console, there are 2 screws on each side and one hiding behind the glove box door. Once the screws are out, you'll need to unscrew the shifter **** and then lift up on the console and it will come out. You'll need to play around with the parking brake to get it to clear.
Step 9:
Loosen the screws on the AC control, but do not try to remove the AC controls
on the left of the dash, remove the air handler button and then the black plastic cover
behind it. remove the two Phillips screws inside there.
Step 10:
Remove the glove box and the one or two 12mm bolts that are hiding behind it.
Step 11:
The dash should now be ready for removal, gently pull it straight out. Note - the ac controls stay in the car.
CRX Forum
Old Oct 13, 2002 | 10:09 PM
thanx didnt take as long as i thought it would
Old Oct 13, 2002 | 10:19 PM
Urban Business
Guest
Posts: n/a
ROFL ask superhatch how he did it cut the ****** out EHHEHEHE ROFL
Old Oct 14, 2002 | 12:15 AM
Default Re: dash removal? (TorteX)
Finally got it out. started at 12:30am and finished around 4am. now just to get pedals and install.
Old Mar 3, 2006 | 01:59 PM
RCautoworks's Avatar
thanks
Old Mar 3, 2006 | 02:01 PM
More links crxforum gave me
https://honda-tech.com/zerothread?id=846083
https://honda-tech.com/zerothread?id=433518
https://honda-tech.com/zerothread?id=305869
https://honda-tech.com/zerothread?id=191509
https://honda-tech.com/zerothread?id=130479
89crxhf
12
Oct 7, 2012 09:18 PM
saywhat
May 11, 2006 01:33 PM
masteroflife67
Sep 29, 2005 03:27 PM
toooslow
May 27, 2003 02:00 PM
charjacq
10
Feb 16, 2002 07:23 AM
