Feed line for 676x
Old May 23, 2012 | 06:38 PM
SPOOLINmatt's Avatar
Default Feed line for 676x
What size are YOU using for your 676x JB Precision turbo.
GO!
Old May 23, 2012 | 06:41 PM
ec97civic's Avatar
Default Re: Feed line for 676x
-4
Old May 23, 2012 | 07:24 PM
Redline130's Avatar
-3
Old May 23, 2012 | 07:25 PM
B R Fittings's Avatar
-3 will supply plenty of oil.
Old May 23, 2012 | 07:38 PM
94lsvturbo's Avatar
-3
Old May 23, 2012 | 07:44 PM
sanman000719's Avatar
-3
Old May 23, 2012 | 10:57 PM
Zer0_SpeedWorks's Avatar
-3
All the pte jb billet we bought used -4 all failed,bent shaft,compwheel hitting the housing.
We are very lucky interms of reliability with bw and garrett units.
Old May 24, 2012 | 02:57 AM
justnprsh07's Avatar
-4 with restrictor and turbo is still truckin along and it's on it's 4th car now
Old May 24, 2012 | 01:01 PM
I have a -4 and I'm already feeling like its huffing smoke. Bout to step it down.
Old May 24, 2012 | 01:25 PM
chapnutz1's Avatar
-3 feed, -12 return per PTE
Old May 24, 2012 | 01:29 PM
Blown90hatcH's Avatar
Last time I talked to the guys at PTE, they recommended a -4 feed w/o restrictor for the 676X journal bearing turbo. This was back in December so maybe something has changed?
Old May 24, 2012 | 02:47 PM
ec97civic's Avatar
PTE said -4 when i blew mine up
Old May 24, 2012 | 02:49 PM
bads2k's Avatar
ihad a -4 no restrictor and started blowing oil. but after about a 2 years but not a lot of passes
Old May 24, 2012 | 03:07 PM
I just don't know. Seems like im bout to drop it a little. I know the oil pressure in our cars is donkey tough
Old May 24, 2012 | 04:51 PM
v.i.gsr's Avatar
-3 with a restrictor....
Old May 24, 2012 | 05:01 PM
Garage 808 Hatch's Avatar
-3 on one, -3 with restrictor on another
Old May 24, 2012 | 05:07 PM
you guys are running restrictors on Journal Bearings?
Old May 24, 2012 | 07:00 PM
92redhatch's Avatar
I run a -4 because that's what pte recomends. I personally believe I should be running a -3 because with a -4 it started blowing oil out the exhaust. I sent the turbo to precision twice under warranty and they repaired the turbo. It's not blowing out oil anymore but I'm almost positive with a -3 I would've never had to go on that head ache. I think instead of recommending a size hose they should recommend a specific oil pressure
Old May 24, 2012 | 08:02 PM
chapnutz1's Avatar
i called a few months ago and was told to use a -3 with a -10 return, if it starts to smoke change to a -12...i went with a -12 anyway because the return line is somewhat long
Old May 26, 2012 | 01:13 AM
Redline130's Avatar
I'm not
Old Jun 3, 2012 | 05:14 PM
well an update I guess
I changed to a -3 feed and I had a dramatic decrease in smoke on my last outting which was june 1. I actually don't even recall seeing ANY smoke as a matter of fact.
Old Jun 3, 2012 | 05:29 PM
Redline130's Avatar
Did you use a restrictor as well?
Old Jun 3, 2012 | 05:48 PM
93supercoupe's Avatar
-4/-10 for our 6766BB per PTE
Old Jun 3, 2012 | 05:56 PM
no
its 1/8npt - 3an on both sides and a -3 line.
Old Jun 4, 2012 | 01:04 AM
Redline130's Avatar
no
Same thing I have with my 6765, glad it worked out for you.
